Polchinski states in his equation 2.6.14 (in his book String Theory Vol. 1, Introduction to the Bosonic String) that for charges $Q_1$ and $Q_2$ the following equation holds, where $j_i$ is the corresponding current:
$$ [Q_1,Q_2]=\oint\!\frac{\mathrm{d}w}{2\pi i}\text{Res}_{z\rightarrow w}j_1(z)j_2(w).\tag{2.6.14} $$
Now, for the $bc$ conformal field theory, one find that $\{b_m,c_n\}=\delta_{m,-n}$, which can be shown if above equations holds for the anticommutator.
The equation 2.6.14 is stated with the commutator. Why can it also be used with the anticommutator of $b$ and $c$?
kalle
  • 958
To generalize the bosonic eq. (2.6.14) to operators with arbitrary definite Grassmann parity, the commutator on the LHS of eq. (2.6.14) should be replaced with a supercommutator. Similar superization should be done with the implicitly written radial operator ordering ${\cal R}$ on the RHS of eq. (2.6.14). For details, see e.g. my related Phys.SE answer here.
References:
  1. J. Polchinski, String Theory Vol. 1, 1998; eq. (2.6.14).
