-2
lorentz x' = γ(x - vt) We know the time that has passed from each references are different. And it influences the speed of things in each station and bus, but I think that has nothing to do with the position. For example we still can say that x' = x - vt, then in the station 1 second has passed and yet in the bus time has passed in less than 1 second. Isn't it supposed to be like that?
Or let's say, if this world just works like that lorentz-equation. Then based on that equation. Let's say we have 3 objects (A, B, C) which the velocity of A is 0.1c, velocity of B is 0.8c and velocity of C is 0.9c. And imagine if we stop all the time, so there won't be any transformation of energies. Then let's say we are at A and we see the distance of B to C is 1 million years of c. Then while the time still freezing if we change the reference frame to B, based on that equation x'= γ(x-vt) we need to multiply the result by γ. So the distance of B to C won't be 1 million years of c. But γ*(1 millions years of c), whether 0.8 million.. or etc. Does it really work that way? or I misinterpreted something?
nitori
  • 23
Welcome to the site,
The equation I think you are either misreading or was mistyped is probably the special relativity expression for transforming between inertial frames: $$ x' = \gamma(x-vt) $$ where $\gamma = \frac{1}{\sqrt{1-v^2/c^2}}$ is a dimensionless factor (In particular, it does not represent length/distance).
The role of $\gamma$ in the equation is to correctly relate the coordinates of the two inertial frames. Note that in particular for $v \lt\lt c$ , we have $\gamma \approx 1$, and the equation reproduces the Galilean transformation you mentioned $x'=x-vt$. This may give you a feel for why this is a completely sensible expression.
I don't know what is your source, but perhaps if you give it a second look this will make better sense in the context of what you're reading / looking at. Good luck.
Amit
  • 6,024
