Can we motivate the principle of least action with the principle of inertia that causes a mass particle to resist changes in its momentum? After all, the principle of inertia is the starting point and the fundamental assumption of classical mechanics, like the Encyclopædia Britannica states.
Leonhard Euler gave the following consideration in his "Additamentum 2" (1744):
Since all natural phenomena obey a certain maximum or minimum law, there is no doubt that some property must be maximized or minimized in the trajectories of particles acted upon by external forces. However, it does not seem easy to determine which property is minimized from metaphysical principles known a priori. Yet if the trajectories can be determined by a direct method, the property being minimized or maximized by these trajectories can be determined, provided that sufficient care is taken. After considering the effects of external forces and the movements they generate, it seems most consistent with experience to assert that the integrated momentum, i.e. the sum of all momenta contained in the particle’s movement, is the minimized quantity.
We also have the following by Pierre Louis Maupertuis in his "Les Loix" (1746):
When a change occurs in Nature, the Quantity of Action necessary for that change is as small as possible. [...] The Quantity of Action is the product of the Mass of Bodies times their velocity and the distance they travel. When a Body is transported from one place to another, the Action is proportional to the Mass of the Body, to its velocity and to the distance over which it is transported.
Since momentum $p:=mv$ is a conserved kinematical quantity in any inertial frame, it is also a good basis for dynamical considerations. In particular, its change in time takes external "force" and thus we may define $F:=\frac{dp}{dt}$. On the other hand, the inertial resistance provides an alternative dynamical description that considers motion on a large time interval.
When a mass particle changes its position by $\Delta s$, then, according to the principle of inertia, it tends to maintain its momentum with no change in direction or magnitude, ideally $\Delta p = 0$. That is, when the particle has no net external force acting upon it, a product $p (s_2-s_1)>0$ has the minimum value in the sense that the physically realized straight line is the shortest distance between the successive points $s_1$ and $s_2$. If we consider the influence of an external force, we may assume that the inertial resistance holds for every infinitesimal part of the physically realized overall path, and since the successive points on the path are fixed, we may consider the average value formula for path integrals. Therefore, the inertia of motion causes a sum $\sum \overline{p} \cdot \Delta s$ to obtain a minimum value, where $\Delta s$ is an infinitesimal part of the overall path in 3 dimensions, during an infinitesimal time step $\Delta t$, and the average momentum $\overline{p}$ approximates the physically realized momentum on each $\Delta s$. This motivates Euler's form of the least action principle, i.e.,
$$\delta \int p \cdot ds=0.$$
We also have Maupertuis' form of the least action principle:
$$ \int p \cdot ds= \int p \cdot \dot{s} dt=\int 2Tdt.$$
Moreover, in the presence of conservative force, the only possible source of momentum dependent kinetic energy $T$ is position dependent potential energy $V$, and vice versa. The energy flow between $T$ and $V$ means that $\Delta T = -\Delta V$, and this suggests that we can replace $T$ by $-V$ in Maupertuis' form. Since in the both cases we seek to find a minimum, we may consider the sum of the two terms and this motivates Lagrange's form of the least action principle, i.e.,
$$\delta \int (T-V) dt=0.$$
Hulkster
  • 733
We have the following two concepts:
The relation between force, inertial mass, and acceleration: $$ F=ma \tag{1.1} $$
The relation between mechanical potential energy and kinetic energy:
$$ \Delta E_k + \Delta E_p = 0 \tag{1.2} $$
You grant the concept of conservation of mechanical energy, but it appears you think of that as independent from $F=ma$. That is in fact not the case:
$ ds = v \ dt \qquad \qquad (2.1) $
$ a \ dt = dv \qquad \qquad (2.2) $
$ F = ma \qquad \qquad (2.3) $
$ \int_{s_0}^s F \ ds = \int_{s_0}^s ma \ ds \qquad \qquad (2.4) $
$ \int_{s_0}^s a \ ds = \int_{t_0}^t a \ v \ dt = \int_{t_0}^t v \ a \ dt = \int_{v_0}^v v \ dv = \tfrac{1}{2}v^2 - \tfrac{1}{2}v_0^2 \qquad (2.5) $
$ \int_{s_0}^s F \ ds = \tfrac{1}{2}mv^2 - \tfrac{1}{2}mv_0^2 \qquad \qquad (2.6) $
$ \Delta E_p = -\int_{s_0}^s F \ ds \qquad \qquad (2.7) $
$ \Delta E_k = -\Delta E_p \quad \Leftrightarrow \quad \Delta E_k + \Delta E_p = 0 \qquad \qquad (2.8) $
From (2.3) to (2.4):
To both sides of (2.3) the same operation is applied: integration with respect to the position coordinate.
In (2.5) the expression $ \int_{s_0}^s a \ ds $ is developed. The acceleration is unspecified, but we can develop nonetheless because position and acceleration are not independent of each other. In developing the differential is changed twice, according to (2.1) and (2.2), with corresponding change of limits.
(2.7) states the definition of potential energy.
Transformation
We have in general that in physics we can shift from one representation to another by application of a mathematical transformation. In the case of $F=ma$ and $\Delta E_k + \Delta E_p = 0$: those two representations are related by integration.
Conversely: to recover $F=ma$ from $\Delta E_k = -\Delta E_p$ you take the derivative with respect to the position coordinate on both sides.
My point here is: from a physics point of view: to grant $F=ma$ or to grant $\Delta E_k = -\Delta E_p$ is one and the same thing.
We have: in cases where $\Delta E_k + \Delta E_p = 0$ holds good: Hamilton's stationary action will hold good also (no additional assumption required).
Discussion of that is in an answer by me (oktober 2021) to a question about motivation for Lagrangian formalism
Cleonis
  • 24,617
-1
The basic flaw in your argument is that the sum is not zero. It tends to resist but it always doesn't, if you have some infinitesimal movement $\delta x$, you will have some associated change in momentum.
But your final equation is correct, then how would you go about deriving it? You see in the path of least action, you know the Lagrangian is zero for any path at the beginning and end points; so you can impose boundary conditions.
