Question: How do photovoltaic cells actually work?
Here is the standard explanation:
- Photovoltaic cells comprise of an N-P silicon junction. The terminals are in electrical contact with the N and P doped silicon
- At rest, thermal movement of the electrons and holes produces a Depletion Zone. There is an electric field across the depletion zone, pointing from the positively-charged N-doped silicon to the negatively charged P-doped silicon.
- When photons hit the depletion zone, sometimes a photo electron is produced. The liberated electron and hole are attracted to opposite ends of the depletion zone, producing the net charge difference across the PV cell.
That explanation sounds satisfactory, but it can't be the complete story, because it would violate the second law of thermodynamics. Imagine the following thought experiment:
- I have a blackbody in a perfectly reflective and thermally insulated container.
- I have a solar panel pointing at the black body. The wires come out through the container.
- I wait until there is thermal equilibrium, and then I suddenly flick a switch to connect the circuit, and let the electricity from the PV cell do useful electrical work.
Question: Would the PV cell generate electricity in this case?
No part of the first paragraph would preclude the PV cell from generating electricity in this scenario. But I contend that this would violate the second law of thermodynamics. The PV cell would be converting the blackbody radiation (heat) entirely into useful electrical work, without the need to dump waste heat into a heat sink.
Basically, this would be a heat engine with a heat reservoir, but no need for a heat sink!!
