Suppose we have primary fields $A$ and $B$ which have the OPE,
$$A(z) B(w) = \frac{1}{z-w} = -B(z)A(w), \quad |z| > |w|,\tag{1}$$
so they have fermionic statistics. Now I was curious how this would affect computing their commutation relations, using the usual contour integral approach. If $A$ has weight $h$ and $B$ has weight $h'$, I can get the modes using,
$$A_m = \oint \mathrm dz \, z^{m+h-1} A(z), \quad B_n = \oint \mathrm dw\, w^{n+h'-1} B(w),\tag{2}$$
where the contour integrals encircle $z=0$ and $w=0$ respectively. Then normally we would write,
$$[A_n,B_n] = \oint_{C_1} \mathrm dw \oint_{C_2} \mathrm dz \, z^{m+h-1} w^{n+h'-1}A(z) B(w),\tag{3}$$
where $C_1$ is an integral around $w=0$ and $C_2$ is an integral around $z=w$. This much has been explained in previous questions, but I think this wouldn't be valid for fermionic statistics? Since in writing out the commutator, you swap the fields and pick up a minus sign, but then I am not sure which contour integration you would carry out.
I would appreciate any clarification because I cannot find an example where this is carried out for the free fermion, for example.
  1. For Grassmann-odd fields, the OPE construction works in much the same way as for Grassmann-even fields with the only change that the LHS of eq. (3) should be the anticommutator (rather than the the commutator).
  2. Also it should probably be stressed that the RHS of eq. (3) contains an implicitly written radial operator ordering ${\cal R}$. Similarly, eq. (1) should properly read $$\begin{align} {\cal R}[A(z) B(w)] ~=~&\theta(|z|\!-\!|w|)A(z) B(w)\cr &~+~ (-1)^{|A||B|}\theta(|w|\!-\!|z|)B(w)A(z) \cr ~=~& \frac{1}{z-w} + \text{non-singular terms}.\end{align}\tag{1'}$$
  3. The Grassmann-even construction is reviewed in this Phys.SE post.
References:
  1. P. Di Francesco, P. Mathieu and D. Senechal, CFT, 1997; section 6.4.
