Suppose I want to measure the length of an object in front of me, along the axis separating us (for instance looking headlong at a bus, we could talk about someone standing inside the middle of the bus with a light signal and mirror, but you get the idea).
Let's say in the rest frame of the bus I measure a length $\mathcal{L}_{0}$. Now, suppose I boost into an accelerated frame with relative velocity v, the length is now observed to be:
$$\mathcal{L}=\mathcal{L}_{0}\sqrt{1-\left(v/c\right)^{2}}$$ I could imagine repeating the boosting several times, while only going into an inertial frame momentarily to measure the length. It would appear as though the “bus” is shortening with a measurable speed:
$$\frac{d\mathcal{L}}{dt}=\frac{d}{dt}\mathcal{L}_{0}\sqrt{1-\left(v/c\right)^{2}}$$
$$=\frac{\mathcal{L}_{0}}{c^{2}}\frac{\left(-v\right)}{\sqrt{1-\left(v/c\right)^{2}}}\frac{dv}{dt}$$
I understand special relativisticaly how this occurs, but now we have acceleration and noninertial reference frames. This is more the purview of General relativity. How would I go about calculating this observed “speed of length contraction” properly for some constant acceleration and relative velocity? I'm guessing there's more to the story? I'm very familiar with GR, but for some reason this is stumping me.
Also, an accelerating observer should have a time dilation due to acceleration and not just velocity, I'm not sure where that fits in
R. Rankin
  • 2,925
  • 16
  • 27
If $\rm \ L(t)=L_0/\gamma(t)=L_0 \sqrt{1-v(t)^2/c^2}$
then $\rm \ L'(t)=dL/dt=-L_0 v'(t) \ v(t) \ \gamma(t)/c^2$
see here and here.
Yukterez
  • 14,655
