Well, I was traveling in a bus yesterday and saw this occur. The board that separates the passengers from the driver's had something written on it and I saw that the window that was a few meters away from the board reflected all of the things written.. But the window had some dirt on the part where I saw the image of the writings... And, they appeared to be enlarged just at the point where dirt was present.
Asked
Active
Viewed 140 times
The open spaces between dirt particles each acts like a "pinhole camera" to magnify the image behind the dirty glass pane. The magnification is slight but noticeable. Try this experiment: make a small triangular hole shape by putting three fingertips together so as to leave a gap at their intersection. by pressing your fingertips together, you can make the size of the hole shrink; by relaxing them, you can make the hole larger.
That hole will act as a pinhole camera. now look through the hole at your computer screen from about 24 inches away and vary the hole size. you will find a certain diameter at which the image you see through the hole will get sharper and the text on the screen will become easier to read.
niels nielsen
- 99,024
