I was curious to know the logic behind “Planck Units”, I read this question but did not understand it. Do you have a better (simpler) explanation for setting $c = G = \hbar = 1$?
The numeric values for dimensionful quantities are actually their ratio with some arbitrary standard that has same dimension. So when you say your length $L=10$ meters it means $L$ is ten times longer than some stick which was called a "meter". Alternatively you can say that $L$ is 100 times longer than another stick called "decimeter". Obviously this is by no means same as proclaiming $100=10$.
In your example in the comments, saying that $c=1$ is not like saying $1 = 299792458$. Instead it means saying that $c= 299792458$m/s=$1\,[299792458\,\mathrm{meters]/second}$. So putting $c=1$ is equivalent to defining a new length unit (call it "zeynel") which is equal to
1 zeynel = 299792458 meters
Then the speed of light $c=1$ zeynel/second. So to summarize, you never set dimensionful quantities to 1 (or any other number for that matter), instead you pick a new set of "standard sticks" in the units of which, those quantities have a numeric value 1 (like $c=1$ zeynel per second).
- 4,287
Quoting from the Appendix on Units and Dimensions in J.D. Jackson's Classical Electrodynamics, it is important to understand "The arbitrariness in the number of fundamental units and in the dimensions of any physical quantity in terms of those units".
Max Planck similarly noted:
The fact that when a definite physical quantity is measured in two different systems of units it has not only different numerical values, but also different dimensions has often been interpreted as an inconsistency that demands explanation, and has given rise to the question of the 'real' dimensions of a physical quantity. … it is clear that this question has no more sense than inquiring into the 'real' name of an object"
The logic behind Planck units is the same as for most systems of units: they are convenient for use in a particular context. Planck units simplify some equations and relationships frequently used in some areas of physics. This is the same reason why there used to be multiple systems of electromagnetic units in common use, such as esu, emu, and cgs, that each made different equations and calculations simpler in some context, but confused generations of students. For example, only the SI system had an independent unit for electric charge (the Coulomb), while the others defined electric charge in different ways in terms of length, time, and mass.
In a unit system where "$c=1$", $c$ serves as a conversion constant between length and time, e.g. 299792458 metres = 1 second. Similarly, setting $\hbar=1$ provides a conversion constant between energy and time. Given $\hbar=c=1$, setting $G=1$ essentially defines the base unit. If you calculate an energy to be "$1$" in Planck units, that is equal to $1.2209\times10^{19}$ GeV or $1.9561$ GJ. It is certainly confusing at first, but eventually become "natural" if you work with it every day.
- 13,658
