-1
Suppose a pair of entangled particles having opposite up/down spins are produced on Earth.
These two particles are then separated, one remaining on Earth, and the entangled pair being brought by colonists to Alpha Centauri.
When the colonists have successfully settled in Alpha Centauri, they perform an explicit measurement of the spin of their entangled particle, by passing it through an inhomogeneous magnetic field (Stern Gerlach measurement).
This measurement in Alpha Centauri fundamentally changes the yet unmeasured particle pair left on Earth. Its spin has now changed from being indeterminate to being decidedly up or down, even before we measure it.
Could there be a Bell test that can be performed here on Earth, by once more entangling this yet unmeasured particle on earth with another particle, then performing a Bell test to measure their super correlation?
A particle with already pre-determined spin (due to previous measurement of its entangled pair) cannot exhibit telepathic Bell correlation anymore, when given random test environments. Only particle pairs with true un-determined spins can spontaneously collude their spin states to exhibit this super correlation phenomena given random Bell test conditions.
In other words, could there be a Bell test on Earth that tests whether the far away entangled pair in Alpha Centauri had been "opened" or not?
James
  • 637
No -- otherwise, faster-than-light communication would be possible, which is not possible within quantum mechanics.
As an alternative perspective, note that the description the people on earth have of the particle on earth did not change due to the measurement, so any subsequent test to be run on it will return the same outcomes, whether it has been measured or not.
