In an single-electron atom, we consider the electron to be revolving around the nucleus, which remains at rest. But the nucleus should also be, in a way, revolving around the electron, however negligible this effect is. Both the nucleus and the electron would be following the Angular Momentum Quantization rule, therefore when the electron de-excites from a higher energy state, the nucleus must also do so. So my question is will this system release two photons or one?
I've read that the de-excitation of electron will release exactly one photon, regardless of the energy difference, but nothing is mentioned about its effect on the nucleus. Am I conceptually wrong in assuming that the nucleus de-excites from a "higher energy state"? Perhaps this can be better observed in an exotic atom where the orbiting particles are of comparable mass.
The full Schrödinger equation for an atom (let's say hydrogen), includes degrees of freedom for the electron (${\bf r_e}$) and the proton (${\bf r_p}$). They are factored into a center-of-mass motion and a separation:
$$ {\bf r} = {\bf r_e} - {\bf r_p}$$
with reduced mass:
$$ \mu = \frac{m_eM_P}{m_e + M_P} $$
The reduced mass accounts for the proton's complementary motion (which is somewhat classical sounds). Basically in an $L=1$ state, the $Y_1^m(\theta, \phi)$ has the angles defined with respect to ${\bf r}$, so yes: the proton is in a little spherical harmonic too.
Nevertheless, a nominal 1 photon transition occurs when the wave function with respect ${\bf r}$ changes from a higher energy state to a low energy one, and a single photon is emitted.
JEB
  • 42,131
