Consider a massless charged particle uniformly moving in vacuum at a constant velocity with the speed of light. The usual expressions for electric and magnetic fields give weird results in this case. Take electric field as an example — it would show that the field “collapses” into a plane perpendicular to the line of motion.
Usually “infinities” indicate a problem in the theory. So I wonder if such particles can exist theoretically? If I am not mistaken, there are no empirically known examples.
Is it the result of the assumption that the particle is truly a point? Maybe there are some quantum effects to “rescue”?
xaxa
  • 1,672
