So for example in the double slit experiment, you can see the interference pattern on they screen of where the photons hit it. That makes sense to me. What doesn’t is that since in this simulation, if you go to the slits and double slit, you can see the waves propagate. If you put a screen anywhere (vertical), you will get the interference pattern.
What I don’t get is that since the wave is propagating, so do the troughs. So, as time goes on, where there used to be peaks, there are now troughs. So wouldn’t the pattern constantly be flickering?
Since it doesn’t, I assume the electromagnetic wave doesn’t matter in that sense. Since the pattern is formed because of amplitude, it would make sense.
Overall, when would the current “position” of the wave matter, and in what circumstances?
gbe
  • 103
