-1
As you can find in all the literature, the age of the universe can be computed easily $$t_0= (H_0)^{-1} = 14Gy$$
For the accepted values of Hubble constant $H_0$, but recently I read that this result takes the assumption of "constant expansion" (the source is in fact this one this), that is related to the density parameter $\Omega$,
$$\Omega = \frac{\rho}{\rho_c}$$
And this constant expansion we imposed to find the age of the universe happens when $\Omega = 0$, i.e. the universe is empty.
  1. Why is this taken as an approximation, if we know part of the universe is not empty for sure, approximately,
$$\Omega_m = 0.05 \quad \Omega_{DM}=0.25$$
$\qquad $ For matter and dark matter respectively, the 70% left is sufficient to neglect this density?
Also I found that for a universe with the exact critical density $\rho=\rho_c$, i.e. $\Omega =1$. A universe that have the exact necessary density to maintain the expansion and not collapse, the age of the universe will be,
$$t_0=\frac{2}{3H_0}=8Gy$$
That is less than the accepted hypothesis ($14Gy$).
  1. How can this expression $\frac{2}{3H_0}$ be found? And how is related to the expansion rate $H$?
I don't know if I mixed some concept wrong, and I will be thankful for any help.
Euler
  • 529
In ΛCDM, $H(t)^{-1}$ is larger than the age of the universe at early times and smaller than the age of the universe at late times. We just happen to live in the crossover era where they are close in value. $H(t)^{-1}$ isn't, or at least shouldn't be, taken as an approximation of the age of the universe.
If $a \propto t^k$ for some constant $k$ (which is not the case in ΛCDM), then $H_0 \triangleq a'(t_0)/a(t_0) = k/t_0$, and so $t_0 = k/H_0$. If the expansion speed is constant then $a\propto t$, $k=1$, and $t_0 = H_0^{-1}$. In a matter-dominated ($Λ=0$) critical-density cosmology, $a\propto t^{2/3}$, and $t_0 = \frac{2}{3H_0}$. But neither of those expressions for the age of the universe is correct in ΛCDM.
benrg
  • 29,129
