Let there be a rod lying on a frictionless surface (or just in deep space). A constant force $\vec F$ acts on the rod for infinitesimal time internal. The force acts at a point located at some distance from the center of mass of the rod.
The force causes an infinitesimal displacement $dr_{\rm CM}$ of the rod’s CM and an infinitesimal angle $dθ$ of rotation of the rod.
How much does kinetic translational and rotational energy change during this time interval?
My try.
Infinitesimal work done on the rod is
$\delta W = F dr$
Which equals changes of the translational and rotational energies of the rod:
$\delta W = F dr_{\rm CM} + \tau d \theta$
As the time interval is infinitesimal, we can assume that torque is constant and equals:
$\tau = F r$
The angle of rotation equals
$d\theta = \frac{dr}{r}$
So, we have
$\delta W = F dr_{\rm CM} + (F r)(\frac{dr}{r})= F dr_{\rm CM} + F dr$
Now if combine the last expression for δW with the first one, we get
$F dr = F dr_{\rm CM} + F dr$
Where we can see that
$F dr_{\rm CM}=0$
Which means that infinitesimal work on the rod does not change its translational energy. Apparently, this is wrong. What am I missing here?
Sorry my English and thanks in advance!
UPDATE: I’ve found a mistake in my reasoning. It is the infinitesimal angle, which is actually equal to
$d\theta = \frac{dr-dr_{\rm CM}}{r}$
For more detail, see comment №4, below the answer by Farcher.
Alexandr
  • 334
The single force $\vec F$ in your diagram acting at a distance $r$ from the centre of mass of the body can be thought of as a force $F$ acting at the centre of mass of the body and a torque $\vec \tau$ of magnitude $Fr$ acting at the centre of mass of the body as shown here.
So the translational acceleration, $a$, of the body is given by the expression $F=ma$ and the angular acceleration of the body, $\alpha$, is given by $\tau =I_{\rm cm}\alpha$.
The change in the translational kinetic energy of the body is $F\,\delta x$ where $\delta x $ is the translational displacement of the centre of mass of the body and the change in rotational kinetic energy of the body is $Fr\,\delta \theta$ where $\delta \theta $ is the rotational displacement about the centre of mass of the body.
Farcher
  • 104,498
