The both sides of below equation don't give the same units, e.g. $$ \frac{\delta}{\delta \phi (\tau)}\int_a^b \phi (\tau') d\tau'=1\;. $$ where $a<\tau<b$. To show this assume that the field $\phi$ has "$j$" unit and $\tau$ has "$s$" unit then $$ [\frac{1}{j} j s] \neq [ 1 ]. $$ What's wrong with my reasoning?
Regardless of the context and the meaning of the symbols, both sides of the equation have perfectly the same units: they are dimensionless.
The integral has units $js$ as you write, using your notation, but the functional derivative has the compensating units $1/(js)$ so the units cancel.
To see that dimension of the functional derivative is $1/(js)$, one may use a more general "defining" identity for the functional derivatives $$ \frac{\delta}{\delta \phi(\tau)} \phi(\tau') = \delta(\tau-\tau') $$ which is the continuous-index counterpart of $\partial / \partial x_i (x_j) = \delta_i^j$. The units of the functional derivative would be just $1/j$ – canceling that of $\phi$ itself – if the delta-function on the right hand side were dimensionless, like the Kronecker delta. But it's not. The delta-function may be written as the $\tau$-derivative of the dimensionless step function (zero for negative arguments, one for positive arguments), so its units are $1/s$ (the inverse units to the units of the argument, in this case $\tau$), which means that the units of $\delta / \delta \phi(\tau)$ have an extra $1/s$ as well, to get the total units $1/(js)$.
- 182,599
