I am studying electrostatics from Griffiths book, and was seeing the calculation of electric field due to an infinite wire by Gauss's Law, by taking a Gaussian cylinder.
  1. My doubt is, why we are finding electric field at a distance z from the wire and not along the axis of a the wire.
Question might not make sense to many readers, but I am facing a hard time understanding the geometry, conceptual problem and visualizing where and where not it doesn't makes sense to find electric field.
  1. And my second doubt is, I do not understand or unable to imagine, how symmetry cancels the contribution of end caps of the Gaussian cylinder and electric field is only due to the curved part of the cylinder. If someone can help me show diagrammatically would be easy to understand it.
Note- For the second part of symmetry where two caps of cylinder makes no contribution in electric field, is it because that two ends are so far away that at a distance z they makes no sense as their contribution would be negligible,
                                  or
The two ends have area vector in opposite direction producing equal amount of electric field and thus cancelling each other fields.
First, let me try to answer your second question.
By cylindrical symmetry, we have: $$ \mathbf{E}(\mathbf{r}) = E(\rho) \, \hat{\mathbf{\rho}} $$ Now, the Gauss law states that $$ \oint_S \mathbf{E} \cdot d\mathbf{a} = \frac{Q_{enc}}{\varepsilon_0} $$ where $S$ is the gaussian surface of our choice. If we choose a cylinder of radius $\rho$ and length $L$, then we have (writing $d\mathbf{a}$ in cylindrical coordinates) $$ \oint_S \mathbf{E} \cdot d\mathbf{a} = \int_0^{2\pi} \int_0^L (E(\rho) \, \hat{\mathbf{\rho}}) \cdot (\rho \, d\phi \, dz \, \hat{\mathbf{\rho}}) \; + \; 2 \int_0^r \int_0^{2\pi} (E(\rho) \, \hat{\mathbf{\rho}}) \cdot (\rho \, d\rho \, d\phi \, \hat{\mathbf{z}}) $$ $\hat{\mathbf{\rho}}$ and $\hat{\mathbf{z}}$ make up an orthonormal basis, thus $\hat{\mathbf{\rho}} \cdot \hat{\mathbf{z}} = 0$, and we have $$ \int_0^{2\pi} \int_0^L (E(\rho) \, \hat{\mathbf{\rho}}) \cdot (\rho \, d\phi \, dz \, \hat{\mathbf{\rho}}) \; + \; 2 \int_0^r \int_0^{2\pi} (E(\rho) \, \hat{\mathbf{\rho}}) \cdot (\rho \, d\rho \, d\phi \, \hat{\mathbf{z}}) = \int_0^{2\pi} \int_0^L (E(\rho) \, \hat{\mathbf{\rho}}) \cdot (\rho \, d\phi \, dz \, \hat{\mathbf{\rho}}) = E(\rho) \rho \int_0^{2\pi} \int_0^L d\phi \, dz = 2 \pi \rho L \, E(\rho) $$ The last equality holds because we do not integrate over $\rho$ and $E$ only depends on $\rho$.
In terms of visual intuition, you can think of it this way: the infinite cylinder is a "sum" of infinite number of point charges positioned in a line. The line is infinitely long, thus each field component in $z$ direction is cancelled by "neighbouring" point charges. As a result, the field depends only on the distance from the axis, which is just another way of saying that the field is cylindrically symmetric.
As you finish the calculation, you'll notice that the field is proportional to $\frac{1}{\rho}$. Thus, it is not sensible to ask about the field on the axis, because as $\rho \rightarrow 0$, $E \rightarrow \infty$.
sbaginski
  • 188
