On page 183 of Peskin and Schroeder, we have the following scattering cross section
$$\tag{6.23}d\sigma(p\rightarrow p'+\gamma)=d\sigma(p\rightarrow p')\cdot \int\,\frac{d^3k}{(2\pi)^3}\frac{1}{2k}\sum_{\lambda=1,2}e^2\bigg|\frac{p'\cdot\epsilon^{(\lambda)}}{p'\cdot k}-\frac{p\cdot\epsilon^{(\lambda)}}{p\cdot k}\bigg|$$
My question is that $\frac{1}{2k}$ makes no sense because $k$ is a 4 vector. Should it be $\frac{1}{2k^0}$ instead?
Then Peskin and Schroeder claims that the differential probability of radiating a photon with momentum $k$, given that the electron scatters from $p$ to $p'$ is
$$\tag{6.24}d(\text{prob})=\frac{d^3k}{(2\pi)^3}\sum_{\lambda}\frac{e^2}{2k}\bigg|\boldsymbol{\epsilon_\lambda}\cdot\Big(\frac{\boldsymbol{p'}}{p'\cdot k}-\frac{\boldsymbol{p}}{p\cdot k}\Big)\bigg|^2$$
How does 6.23 give 6.24? In 6.23 we have four vector dot products $p'\cdot \epsilon^{(\lambda)}$ whereas in 6.24 we have three vector dot products.
Peskin and Schroeder then goes on to say that when we integrate over the photon momentum, we have
$$\tag{6.25} \text{Total probability}\approx\frac{\alpha}{\pi}\int_0^{|\boldsymbol{q}|}dk\frac{1}{k}I(\boldsymbol{v},\boldsymbol{v'})$$ where $I(\boldsymbol{v},\boldsymbol{v'})$ does not depend on $k$. But how does 6.25 follow from 6.24? In 6.24 the denominators have $p'\cdot k$.
