I am trying to understand the physical meaning of the wavenumber, which as explained in wikipedia, is the magnitude of the wave vector, which, if I am not mistaken, the wave vector gives information about the direction of the propagation of an EM/Matter-wave.
The crystallographic def. of the wave number, is pretty clear to me:
$$k=\frac 1 \lambda$$
the number of complete cycles that exist in 1 meter of linear space. A complete cycle translates in space as the distance between two points which have a $2\pi$ phase difference between each other (in other words points of same phase), and this distance is equal to a wavelength $\lambda$. This is how I understand the wave number definition in crystallography. If I am wrong about something, please let me know.
In theoretical physics, the formula is:
$$k=\frac{2\pi}{\lambda}$$
and it's interpreted as the number of radians per unit distance, sometimes called "angular wavenumber". I don't understand this. And I cannot see how the wave numbers of two waves with different wavelengths $\lambda_1$,$\lambda_2$, would be different (considering the above formula).
As I said above, 1 wavelength, is a full cycle, which is $2\pi$ radian. This should be valid for both waves. The only difference, is the number of full cycles per unit of time, in other words the frequency.
What am I getting wrong here?
