What is the meaning of $k_B T$? in physics, where $k_B$ is Boltzmann constant? Is there a maximum for it? Can you give a maximum or minimum value for it among all the material? Or is there any typical value for this?
Asked
Active
Viewed 209 times
$kT$ is an estimate of the energy that a system has due to its temperature being $T$, or given to it when its environment is at temperature $T$.
It has an obvious minimum (zero), but its maximum value is typically limited by practical factors (like the system being destroyed if temperature becomes too high, or the theory stepping outside its validity domain).
The only absolute maximum that can be mentioned is Planck energy, which also yields a temperature value. But what happens at this point is unclear.
Miyase
- 6,342
assuming T means temperature, I think not for $K_b T$ is an increasing function.
However, this post here on the highest possible temperature suggests a limit, which is $1.4168331(85)×10^{32} J$
