Since our solar system is moving through the milky way galaxy, if we point our telescope to a certain point where we determine that the solar system was a certain time ago, will we see our solar system?
No. You don't see past versions of yourself as you walk around your house. Why would you expect to see past versions of the solar system ?
The finite speed of light means that when we look at other stars and other galaxies we see them as they were when the light that reaches us now was emitted - which can be thousands of years ago for stars in our galaxy, or millions or billions of years ago for other galaxies. But we don't see older versions of our own solar system.
- 63,999
Another way to think about this:
In order to see an event from a thousand years ago, you need to look at locations that are a thousand light-years away. This is because light from that event must have been traveling for a thousand years. However, the Earth of a thousand years ago cannot be at any location that far away because it moves through space slower than the speed of light. This means that the light emitted from events on Earth a thousand years ago has already passed by the Earth's present location. All of that light is now moving away from us out into space, never to be seen by us.
There is one way light from the past could return to Earth. If there is a black hole 500 light-years away, then light from an event could make a U-turn around the black hole and be sent back to Earth's present location. See this article and the video within about light orbits around black holes to see what this looks like. It would be very difficult to disentagle the light from Earth from all the other light flung about by the black hole, but it would be in there.
- 25,556
