Sand runs from a hopper at a constant rate $\frac{dm}{dt}$ onto a horizontal conveyer belt driven at a constant speed $v$ by a motor. The power needed to drive the belt can be calculated as follows:
Momentum change of sand mass $dm$ is $dp=vdm$. The force $F$ on the belt is $$F=\frac{dp}{dt}=v\frac{dm}{dt}$$ The power $P$ to drive the belt is $$P=Fv=v^2\frac{dm}{dt}$$ Now, let us calculate the rate of change of kinetic energy of the sand: $$\frac{dK}{dt}=\frac{1}{2}\frac{dm}{dt}v^2$$ Half the power given to the belt goes to giving kinetic energy energy to the sand. My question is, where does the other half go?
Aarone
  • 378
