Im confused on what the significance of exact differentials are in physics, specifically in thermodynamics. In my book posted here it talks about how by requiring that $dU$ be exact it leads to equation (1.4). So my questions are, How and why do we have the requirement that $dU$ be exact? What do exact differentials tell us in physics in general and in thermodynamics and what do they allow us to do?
First, requiring $dU$ to be exact leads to (1.4) because of Clairaut's Theorem - just to clear things up.
Now, the requirement for $dU$ to be exact comes from the fact that it's a state variable. That means that if you have some process in which your system evolves into different states, eventually going back to the original one, $U$ will not have changed, no matter what said process was. Mathematically, this can be represented using line integrals as:
$$\oint dU=0 $$
The integral over a closed loop of internal energy is $0$. This can also be called path independence. Now, there is a theorem in multivariable calculus, the gradient theorem that states that for a function to hold this condition, it must be the gradient of some other function. Another common result is that $dF=\nabla F \cdot d\vec{r}$. This is also the definition of an exact differential.
In other words, $dU$ is exact because then, you have (1.3) as your book states, which can be rewritten as $dU=\nabla U \cdot d\vec{r}$ where $\vec{r}$ is the vector for the volume-pressure space. And then, you have the integral condition stated above which is required for a state variable such as $U$.
agaminon
  • 4,386
The other answer gave you a mathematical perspective. This will provide a physical perspective.
Physically, the difference between an exact differential and an inexact differential with respect to thermodynamic variables is that an exact differential is a differential "change" in a quantity whereas an inexact differential is a differential "amount" of a quantity.
"Changes" are associated with thermodynamic properties such as internal energy, entropy, pressure, temperature, volume, i.e., the properties of a system. "Amounts" are associated with quantities that are not thermodynamic properties, chiefly work and heat.
So the differential version of the first law is commonly written as
$$du=\delta q - \delta w$$
where $du$ is the differential change in internal energy whereas $\delta q$ and $\delta w$ are the differential amounts of energy transferred between the system and the surroundings in the form of heat and work, which are not thermodynamic properties.
Hope this helps.
Bob D
  • 81,786
