Is there any solution to Einstein's field equation left to be discovered?
Is it still possible to get a solution of Einstein's field equation?
And is every mathematical solution of Einstein's field equation physically valid?
hft
  • 27,235
Quick answer is no.
There is no general analytical technique to take a given stress-energy tensor and solve for the metric.
Treated as a numerical task (solving by computer numerical integration methods) the task is also extremely challenging. For many cases of interest the numerical methods on large modern computer networks can only yield rough answers.
A further difficulty is that one might not even know how to get the stress-energy tensor until the metric is known. This happens for example when the gravitational effects are very large (typically neutron stars and black holes).
Of course even in Newtonian physics the three-body problem is known to be also very challenging.
Andrew Steane
  • 65,285
Probably most of the interesting solutions have been found yet. Anyway, all the time someone is publishing new solutions, for example two months ago this new exact solution was found.
Is it still possible to get solution of Einstein's field equation?
The above recent solution corresponds to an anisotropic matter distribution. If you try to find solutions for exotic or uncommon matter distribution, possibly you can find solutions previously unnoticed. However, the general procedures that have been used have already generated hundreds of qualitatively different solutions and it will be increasingly difficult to find new solutions, especially if they correspond to particularly simple matter distributions.
And do every mathematical solution of Einstein's field equation can be physically valid?
Almost certainly not, the white holes are an exact solution of Einstein's equations, but almost no one believes they are physically possible solutions for a host of reasons. Likewise, some of the best-known solutions lead to mathematical singularities, which ultimately physically could be something else (a future theory of quantum gravity should make it clear to us what those surely unphysical singularities we see in GR correspond to).
Urb
  • 2,724
Davius
  • 1,700
Yes, infinitely many.
Yes, for example, if you restrict yourself to static spherically symmetric perfect fluid solutions you can find a new one by solving that second order linear differential equation https://physics.stackexchange.com/a/679431. Personally, I have found some new solutions that have been not yet published.
The consensus among relativists is no. I think otherwise.
JanG
  • 2,237
