I am trying to understand the math here. How long would it take for an upright rigid body to fall to the ground? But I am lacking in some basic mathematical concept/techniques.
In several answers, an estimate is given that the angular acceleration can be approximated as
$\ddot{\theta}=\dfrac{g}{h}\theta \tag{1}$
Which can be approximated as
$t=\sqrt{\dfrac{h}{g}} \ln\left(\dfrac{\theta}{\theta_0}\right) \tag{2}$
Could someone kindly explain the steps/method to go from equation 1 to equation 2?
This is not a complete solution but may help you analyse it.
My assumption is that you have a rigid body on the point of toppling and you want to know when it will have rotated 90 deg to hit the surface.
Torque (or moment) and Moment of Inertia (MOI, or Second moment of mass) are kind of analogous with force and mass and we have the relationship
Torque = I x Alpha
where I is the MOI and Alpha is angular acceleration. MOI is highly dependant on the geometry of the object, and needs to be calculated 'about the pivot point'.
So to get to an expression for theta you need to integrate twice from the expression for Alpha
Now the torque is not constant. If the centre of mass (m) is at height h then the torque is equal to (h cos theta x m x g)
Once you have the expression for Theta in terms of h, m, and I, then solve for theta = 90 deg.
Wreckless
  • 336
Due to my poorly written question, I unfortunately did not get a satisfactory answer. After much studying and some experiments, my own solution differs from the linked question's solution. Here is my solution.
Given the equation, find $t$, the time it takes to go from $\theta_0$ to $\theta_t$, with intial condition $\theta'_0 = 0$ $$\theta''=\frac{g}hθ\tag{1}$$
Part 1 solve the differential equation
substitute $$\theta=e^{rt}, \theta''=r^2e^{rt}, $$ and get $$r^2e^{rt}=\frac{g}he^{rt}$$ $$\Rightarrow r=\sqrt{\frac{g}h}$$
solution for $\theta$ $$\theta_t = C_{1}e^{rt} + C_{2}e^{-rt} \tag{1a}$$ differentiate both sides $$\theta'_t = rC_{1}e^{rt} - rC_{2}e^{-rt}\tag{1b} $$
solve $(1a)$ and $(1b)$ using intial value $\theta'_0 = 0$, $$C1 = C2 = \frac{\theta_0}2$$
The solution for the differential equation is $$\theta_t=\frac{\theta_0}{2}(e^{\sqrt{\frac{g}h}t} + e^{-\sqrt{\frac{g}h}t})\tag{1c}$$
Part 2, solve for t
For larger values of $t$, the $e^{-rt}$ term has a much smaller contribution to the sum. $$\theta_t\approx\frac{\theta_0}{2}e^{\sqrt{\frac{g}h}t}$$ $$t\approx\sqrt{\frac{h}g}ln|\frac{2\theta_t}{\theta_0}|\tag{2a}$$
However, if $\sqrt{\frac{h}g}t$ is small, the $e^{-rt}$ term cannot be ignored. One way to approximate, is to use the first few terms of the Taylor series of the exponential function. $$e^x=1 + \frac{x}{1!} + \frac{x^2}{2!} + \frac{x^3}{3!} + \frac{x^4}{4!} + ...$$ then $$e^x + e^{-x}=2(1 + \frac{x^2}{2!} + \frac{x^4}{4!} + ...)$$ $$\Rightarrow e^x + e^{-x}\approx2(1 + \frac{x^2}{2!} + \frac{x^4}{4!})\tag{2b}$$
let $$y=x^2=(\sqrt{\frac{g}h}t)^2\tag{2c}$$ subsitute $(2b)$ and $(2c)$ into $(1c)$ $$\theta_t\approx\theta_0(1 + \frac{y}{2!} + \frac{y^2}{4!})$$ $$\frac{\theta_0}{4!}y^2 + \frac{\theta_0}{2!}y + (\theta_0-\theta_t) = 0\tag{2d}$$
solve for $y$ using quadratic formula, and finally $$t=\sqrt{\frac{h}g}\sqrt{y}$$
