M12 = M21= M (say) (6.14) We have demonstrated this equality for long co-axial solenoids. However, the relationship is far more general. Note that if the inner solenoid was much shorter than (and placed well inside) the outer solenoid, then we could still have calculated the flux linkage N1Φ1 because the inner solenoid is effectively immersed in a uniform magnetic field due to the outer solenoid. In this case, the calculation of M12 would be easy. However, it would be extremely difficult to calculate the flux linkage with the outer solenoid as the magnetic field due to the inner solenoid would vary across the length as well as the cross-section of the outer solenoid. Therefore, the calculation of M21 would also be extremely difficult in this case. The equality M12=M21 is very useful in such a situation
here M12 and M21 are the flux linkage constnats, which is, unless I'm mistaken henry's constant.
This is what my book has to say on this topic. However, they have only derived this relation assuming both solenoids are for all practical purposes, of the same length. Why is this true even when the other solenoid is much shorter than the inner solenoid?
Does this have anything to do with the fact that the magnetic field outside a solenoid is approximately zero?
Moreover, is this also true if the solenoids intersect at say an angle?
