A while back I was looking into the concept of entropy and trying to understand it.
I am relatively familiar with the statistical mechanical and classical definitions, but I'm not that great at physics, so I'm not sure how firm my grasp is. However, I've been thinking of this sort of information-based interpretation.
My interpretation would basically say that the entropy term (T * S) of an energy equation is any energy that is not explicitly accounted for in another way. So the total energy of a system is divided into two categories: 1) information, which is explicitly accounted for as kinetic or potential or internal energy, or 2) entropy, which is "unlabeled" energy.
In this equation, entropy is interpreted as "lost work." My thought is that we can consider "information" to be the energy accounted for in a set of equations that are attributed to explicitly identified entities in the system.
In a heat engine system, the two reservoirs as well as whatever is having work done on it are identified, and they have terms associated with them which account for the energy that is contained within or is a part of them. The energy which is "lost" is precisely the energy which is not flowing into a body which is explicitly referenced in the equation. If it were explicitly referenced, we would consider it to be reversible work done on that body.
In a chemical reaction, it seems the "labeled" elements are the reactants, the products, and the overall system. The heat is considered as work done on the system, and the internal energies of each reactant and product are considered. Any other energy is considered irreversibly lost.
In statistical mechanics, it's a little tougher. Each possible state is labeled, so there is no possibility of something being totally "unlabeled." But the system is only in those labeled states probabilistically, so the labels themselves are uncertain. Knowing which state a system is in allows us to extract energy via something like Maxwell's demon, however if we only know the state probabilistically, then Maxwell's demon has a maximum amount of efficiency. So in this case the extent to which particles are "labeled" is continuous based on how much information is in the probability distribution of its states. However the entropy ends up measuring not how "labeled" the system is but precisely how "unlabeled" it is. A system with maximum entropy will have equal probability of all states, and so the distinction between the different labels will be useless. A system in which any state is equally probably cannot have any energy extracted via Maxwell's demon. So in this case what is being calculated is essentially the accuracy of the labels.
Is this interpretation accepted or valid at all? Is it close to being valid? Is it just dead wrong for obvious reasons that I'm not seeing?
