I've recently read this experiment:
Consider two observers, one standing still and the other one driving down the drag strip in a car at 120mph. According to special relativity the if standing observer meassures 30 seconds on his watch the one in the car will meassure 29.99999999999952 seconds. (Paraphrased Brian green - The Elegant Universe)
The author doesn't state if the car is standing still at time $t=0$ or if it's already going at 120mph.
Assuming the car undergoes no acceleration and thus both observers are in a inertial frames of reference ( assume flat spacetime). Why are we able to say, by comparing the times on the watches, which observer is going at a speed 120mph? I would have thought that one observer $A$ going in one direction at 120mph while observer $B$ is standing is the same as observer $B$ going 120mph while $A$ is standing.
The only explanation I have for this is that we can't really compare both times without unless one observers undergoes some sort of acceleration or a light signal is sent from one observer to another. This is just a hunch and I'm not sure how would I go around showing this.
Could anyone please provide some further explanation?
Edit: I've realized they both stop the time after crossing the finish line so my explanation certainly don't hold, the question still stands.
Edit #2: Thank you very much for all your answer, sadly I can't mark multiple answer as right even though you all provided valuable insight. I've done the some calculation and It appears that is that to a "standing obsever" (relative to earth) who meassures 30 seconds on his watch, in flat spacetime that the moving observer meassures 29.99999999999952 seconds by the time dialation formula $$\Delta t' = \frac{\Delta t}{\sqrt{1-\frac{v^2}{c^2}}}$$ this roughly agrees with the numbers given. From this we can assert that the observer was really already going at 120mph at $t = 0$, another thing that this is that this setup doesn't consider the time it will take light to travel from the finish line to the standing observer.
