I am studying the following hamiltonian, consisting of a double quantum dot system
\begin{align} \hat{H}_{2QD} = \sum_{i=1,2}v_{i}\hat{n}_{i}+\sum_{i=1,2}U_{i}\hat{n}_{i\uparrow}\hat{n}_{i\downarrow} + U_{12}\hat{n}_{i}\hat{n}_{j} \end{align} where $\hat{n}_{i\sigma}=d_{i\sigma}^{\dagger}d_{i\sigma}$ is the number operator, $\hat{n}_i=\hat{n}_{i\uparrow}+\hat{n}_{i\downarrow}$ and $d_{i\sigma}$ ($d_{i\sigma}^\dagger$) are the annihilation (creation) operators for orbital $i$ and spin $\sigma$. Also, $v_{i}$ and $U_{i}$ are the on-site energy (also referred as gate level) and the inter-Coulomb repulsion of the level $i$ and $U_{12}$ is the intra-Coulomb repulsion between the levels 1 and 2.
This hamiltonian is known to be $SU(4)$ invariant, but I'm wondering which transformation explicitly shows this invariance.
If we ignore the orbital index first and consider how the Hubbard interaction $H_h = Un_{\uparrow}n_{\downarrow}$ is SU(2) symmetric. First, we know $n = n_{\uparrow}+n_{\downarrow}$ is SU(2) symmetric because it's the identity matrix in spin representation. And $H_h \sim n^2 = 2n_{\uparrow}n_{\downarrow}+n$, where we used $n_{\sigma}^2 = n_{\sigma}$. We can also explicitly use a Pauli matrix identity $\sum_a\sigma^a_{\alpha\beta}\sigma^a_{\gamma\delta} = 2\delta_{\alpha\delta}\delta_{\beta\gamma}-\delta_{\alpha\beta}\delta_{\gamma\delta}$ to realize ${\bf S}^2 = \sum_a{S^a}{S^a} = \frac{1}{4}(3n-6n_{\uparrow}n_{\downarrow})$.
Introducing back the orbitals, we define $n_t = n_i +n_j$. Notice that $n_t$ is the identity matrix for SU(4) transformations, and $H_{2QD} \sim n_t^2 = n_i^2+n_j^2+2n_in_j$. So if $U_i=U_j = U_{12}$, $H_{2QD}$ is SU(4) symmetric. I don't know a convenient identity to explicitly show it tho.
Probably this is not as smart as QBarista suggested, but you can explicitly check that the Hamiltonian commutes with the 15 generators of the $su(4)$ algebra (or any linear combination of them). Now 6 of them are just spin operators for the $i$-th level, namely $$ \vec{S}_i = \frac{1}{2} \sum_{a,b=\uparrow\downarrow} c^{\dagger}_{ia} \vec{\sigma}_{ab} c_{ib}, $$ where $\vec{\sigma}$ is the vector of Pauli matrices. Another 8 generators are similar to spin $x,y$ operators, but they mix up levels and spins: $$ \frac{1}{2} \left( c^{\dagger}_{1\uparrow} c_{2\uparrow} + \text{hc} \right), \,\,\,\,\,\,\,\,\,\,\, \frac{i}{2} \left( c^{\dagger}_{1\uparrow} c_{2\uparrow} - \text{hc} \right) $$ $$ \frac{1}{2} \left( c^{\dagger}_{1\downarrow} c_{2\downarrow} + \text{hc} \right), \,\,\,\,\,\,\,\,\,\,\, \frac{i}{2} \left( c^{\dagger}_{1\downarrow} c_{2\downarrow} - \text{hc} \right) $$ $$ \frac{1}{2} \left( c^{\dagger}_{1\uparrow} c_{2\downarrow} + \text{hc} \right), \,\,\,\,\,\,\,\,\,\,\, \frac{i}{2} \left( c^{\dagger}_{1\uparrow} c_{2\downarrow} - \text{hc} \right) $$ $$ \frac{1}{2} \left( c^{\dagger}_{1\downarrow} c_{2\uparrow} + \text{hc} \right), \,\,\,\,\,\,\,\,\,\,\, \frac{i}{2} \left( c^{\dagger}_{1\downarrow} c_{2\uparrow} - \text{hc} \right). $$ The last one is a sort of orbital magnetization: $$ n_{1\uparrow} - n_{2\uparrow} $$
Matteo
  • 3,261
