Actually, I am thinking that the fluid pressure occurs as the result of the forces acting on each molecule from each other. If it is true, then why should the horizontal force be equal to the vertical force that is connected to the pressure calculated by hρg?
And also, I want to know whether it would be the same in an accelerating water container. Since it is accelerating shouldn't there be a force difference that leads to an inequality of the pressure in different directions? If it is true, does that mean hρg won't give me the correct answer for horizontal calculations?
Furthermore, I want to know about the pressure of flowing fluids. Will there be equal pressure in all directions if the flow is at a constant speed? Will the pressure vary if it is accelerating?
