I read that free QFT need not be formulated in terms of fields. One can derive the same propagator as the path integral of the single free particle action $\int d{\tau} \eta _{\mu \nu} x^{•\mu}x^{•\nu}$, as long as one also allows paths that go backward in time.
More specifically, the propagator of free QFT is:
$$\int d^4p \frac{e^{-ipx}}{p^2-m^2+i\epsilon}$$
This is also equal to:
$$\int _0^{\infty} d\tau \langle x_2,t_2|e^{-iH\tau}|x_1,t_1\rangle$$
$H$ is $\partial_{\mu}\partial^{\mu} + m^2 -i\epsilon$. This operator generates translations in proper time $\tau$. Then we integrate over $\tau$ to sum over all paths connecting the two spacetime points. Time is treated as just another co-ordinate, so backward-in-time paths are allowed. This calculation is also equal to the path integral of the free particle action.
This calculation also happens to equal $\langle 0|T(\phi(x),\phi(y))|0\rangle$, for a quantum field $\phi$. This "co-incidence" forms the basis of the quantised field forumation of QFT.
The above makes the "quantised field" formulation of QFT seem like a mathematical trick, a co-incidence. Can interacting QFT also be thought of this way, or do we need quantised fields for that?
Ryder Rude
  • 6,915
Feynman originally though that this was possible, but it turns out that if you want to correctly reproduce Bose or Fermi statistics then closed loop diagrams are necessary.
mike stone
  • 58,971
  • 53
  • 158
