Context
In [1], cowlicks asks, ``How can the Gallilean transformations form a group?''. In [1] Selene Routely explains that the Galilean transformations form a group of dimension 10. Routely explains that any transformation "near enough" to the identity can be specified by exactly 10 independent parameters. In this answer, these 10 independent parameters are represented by $\theta\,\gamma_x$, $\theta\,\gamma_y$, $\theta\,\gamma_z$, $v_x$, $v_y$, $v_z$, $X$, $Y$, $Z$, and $\tau$. In [1], Routely explains that the Galilean group can be represented with a set of $5\times 5$ matrices as the group elements, with matrix multiplication as the group operation. Further, she explains that group's elements act on $5\times 1$ column vectors called the homogeneous co-ordinates. Finally, in [1] Routely writes down three three kinds of group elements: Galilean translations, Galilean boosts, and Galilean rotations.
In [2], I ask what type of transformations are we talking about when we talk about Lorentz transformations. The motivation for my question in [2] was to find out what the group is consistent with the postulates of special relativity and that is analogue to the Galilean transformations. In [2] robphy explains that there are two names that are relevant. These names the homogeneous Lorentz group, which is a group of dimension 6, and the inhomogeneous Lorentz group, which is also referred to as the Poincaré group, and which is a group of dimension 10.
Questions
Just as Routely gives the concrete representations of the Galilean translations, Galilean boosts, and Galilean rotations in [1], I want to know their analogues, respectively, in the realm of the Poincaré group.
(1) Translations: What is a concrete representation of those elements of the Poincaré group that describes the transformation between two frames of reference that are neither in relative motion nor rotated with respect to each other?
(2) Boosts: What is a concrete representation of those elements of the Poincaré group that describes the transformation between two frames of reference that are in relative motion but are not rotated with respect to each other?
(3) Rotations: What is a concrete representation of those elements of the Poincaré group that describes the transformation between two frames of reference that are rotated with respect to each other, but are not in relative motion?
My Answer
I have searched Wikipedia. I have found three wikis ([3], [4], and [5]) that are relevant, but none offer a specific representation. In 5, the authors explain that the Poincaré group "is a semidirect product of the translations and the Lorentz group, $$\mathbf{R}^{1,3} \rtimes \operatorname{O}(1, 3) .$$ This semi-direct product gives the structural properties of the group. That said, it does not offer the explicit representations that I am seeking.
With the help of lpz and ZeroTheHero, I gather that the Poincare group's elements might act on $5\times 1$ column vectors of the form:
$$\left(\begin{array}{c}1\\c\,t\\x\\y\\z\end{array}\right)\tag{1}. $$
In (1) $x,\,y,\,z $ are the three spatial co-ordinates, $t$ is the one and only time co-ordinate, and $c$ is the speed of light.
In the case of translations, where there are two frames of reference that are neither in relative motion nor rotated with respect to each other, it seems to me that the situation is exactly like the Galilean case. Thus, adapting from [1], the translations, $T$, are transformations between two frames that are not in relative motion and not rotated with respect to each other. The translations are represented by 5×5 matrices of the following form:
$$T(\tau,\,X,\,Y,\,Z,) = \left( \begin{array}{ccccc} 1&0&0&0&0 \\ c\,\tau & 1& 0 & 0 & 0 \\ X&0&1&0&0 \\ Y & 0 & 0 & 1 & 0 \\ Z & 0 & 0 & 0 & 1 \end{array}\right)\tag{2}.$$
In the case of rotations, I gather that the situation is similar to pure rotations about an arbitrary axis [6]. Thus, for two frames rotated by a fixed angle $ \theta$ about an axis defined by the unit vector [7]: $\hat{\mathbf{u}} = \left(u_1, u_2, u_3\right), $ the rotations, $R$, are represented by $5\times 5$ matrices of the following form:
\begin{align} R( \theta\,u_1,\,\theta\,u_2,\,\theta\,u_3) &= \left( \begin{array}{ccccc} 1&0&0&0&0 \\ 0&1&0&0&0 \\ 0&0& 1 & -\exp(\theta\,u_3) & \exp(\theta\,u_2) \\ 0&0& \exp(\theta\,u_3) & 1 & -\exp(\theta\,u_1) \\ 0&0& -\exp(\theta\,u_2) & \exp(\theta\,u_1) & 1 \end{array} \right) \tag{3}. \end{align}
In the case of boosts, I gather that the situation is similar to Pure boosts in an arbitrary direction [6]. Thus, for two frames moving at constant relative three-velocity $\mathbf{v} = (v_1,v_2,v_3)$ the boosts, $\Lambda$, are represented by $5\times 5$ matrices of the following form:
\begin{align} \Lambda(v_1,v_2,v_3) &= \left( \begin{array}{ccccc} 1&0&0&0&0 \\ 0 & \gamma & -\gamma\frac{v_1}{c} & -\gamma\frac{v_2}{c} & -\gamma\frac{v_3}{c} \\ 0& -\gamma\,\frac{v_1}{c} & (\gamma - 1)\frac{v_1^2}{v^2} + 1 & (\gamma - 1)\frac{v_1\, v_2}{v^2} & (\gamma - 1)\frac{v_1\,v_3}{v^2} \\ 0 & -\gamma\,\frac{v_2}{c} & (\gamma - 1)\frac{v_1\, v_2}{v^2} & (\gamma - 1)\frac{v_2^2}{v^2} + 1 & (\gamma - 1)\frac{v_2\, v_3}{v^2} \\ 0 & -\gamma\,\frac{v_3}{c} & (\gamma - 1)\frac{v_1\, v_3}{v^2} & (\gamma - 1)\frac{v_2\, v_3}{v^2} & (\gamma - 1)\frac{v_3^2}{v^2} + 1 \end{array} \right) \tag{3}. \end{align}
Discussion
Just as the Galilean transformation form a group of dimension 10, so too does the the Poincaré transformation form a group of dimension 10. The same 10 parameters are required to represent the elements of the group. These are: $\tau$, $X$, $Y$, $Z$, $v_1$, $v_2$, $v_3$, $\theta\,u_1$, $\theta\,u_2$, $\theta\,u_3$.
Bibliography
[1] How can the Gallilean transformations form a group?
[2] What we talk about when we talk about Lorentz transformations?
[3] https://en.wikipedia.org/wiki/Lorentz_group
[5] https://en.wikipedia.org/wiki/Poincar%C3%A9_group#Poincar%C3%A9_algebra
[6] https://en.wikipedia.org/w/index.php?title=Four-vector&action=edit§ion=5
[7] https://en.wikipedia.org/wiki/Rodrigues%27_rotation_formula
