In the search for understanding electromagnetism on deeper level, one of the earliest observations was that magnetic field is created around a current carrying wire. Then it was noticed that changing magnetic field can cause electric field to rise.
So, from symmetry it was demanded that magnetic field should also get induced due to changing electric field; and it was true.
My question is, then how could steady current through a wire create magnetic field around it as steady current should mean steady electric field near the region of the wire?
A changing electric field is a source for a magnetic field, but it's not the only source. The other source for magnetic fields is current. So even without a changing electric field we can have a magnetic field induced by the current in the wire.
Rd Basha
  • 2,229
The idea that a changing magnetic field creates and electric field is both frame dependent and a-causal. Maybe it's the curl in the electric field that is changing the magnetic field?
An equivalent formulation of Maxwell's equations by Jefimenko (https://en.wikipedia.org/wiki/Jefimenko%27s_equations) in terms of charges and currents on the past light cone shows that the sources of the electric field are charge, changing charge, and changing current. The sources of magnetic field are current and changing current.
The resulting electric and magnetic fields conform to Maxwell's equations, so that the time derivative of a magnetic field is proportional to the curl of the electric field, but neither field is that cause of the other. They are both created by charge, current, and their time derivates on the past light cone of the point (and time) in question.
JEB
  • 42,131
