Do you know a scenario where the second law of thermodynamics breaks down?
The second law breaks down when some of the assumptions underlying this law (or the thermodynamics itself) are broke.
Among what is typically cited as "violations" of the second law are:
- Violation of the laws of thermodynamics in small systems. Thermodynamics and statistical physics are applicable in thermodynamic limit that is for systems with a huge number of particles. While in some cases this number may be much smaller than the Avogadro number ($N_A\sim 10^{24}$), violation of the thermodynamics in systems with a finite number of degrees-of-freedom is not surprizing. This is equally true for ratchets and billiards.
- Entropy decrease in some systems, notably in living systems. This is again not surprizing, since these are open systems, which exchange energy and matter with the environment. Thus, while the entropy of the system might be decreasing, this is accompanied by the increase of entropy in the environment, and the net entropy is growing. See this answer and this answer for more background.
- 68,984
There is a really cool example I heard of that was published a few years ago, an instance of it actually being violated in practice, not just in theory.
Very roughly, what they did was construct a thermodynamic analogue to an RLC circuit, where energy oscillates back and forth, instead of entropy uniformly increasing by monotonically increasing uniformity of the system.
The key here is that most of what you learn in statistical mechanics is predicated on slow changes of uniform systems. Kinetics and irreversible processes are much subtler. Bear in mind that most popular science is usually not going to go past the face value statement of a physical law.
https://www.media.uzh.ch/en/Press-Releases/2019/Thermodynamic-Magic.html
DOI: 10.1126/sciadv.aat9953
Edit: To add more clarity, their experiment involved two heat reservoirs connected with a Peltier device that had an inductor connecting the terminals. Heat passing through the Peltier device generates a current, the inductor keeps the current going past the point of equilibrium, causing equilibrium overshoot, so the temperature difference appears like a damped harmonic oscillator instead of monotonically going to zero.
- 697
