Why is the work done by the internal forces in a rigid body zero?
Most proof's for that sort of thing seem to assume that the internal forces in the rigid body are in the line attaching the points in between witch they are applied(the internal forces are colinear to the line between the points)
I cannot find why would this assumption be true since these internal forces in objects like thin rigid rods are clearly found to be perpendicular to the rod(for instance while rotating or sifting the rod some parts of it experience only internal forces) whilst they must(apparently) come from the rod's direction thus implying that the forces are perpendicular to the line in between the points.
So how come the internal forces in rigid bodies(including thin rods) add no work to the system?
