According to Newton's 2nd law of motion, F=k(m)(a), where k= constant. Now when F=1,m=1,a=1, then k=1. But when F,m,a each≠1 then the formula is not valid. So how can we say that F=(m)(a) is true everywhere in every case.We also solve questions by taking this formula only.
I'm not sure where your confusion lies. According to Newton's second law of motion, the rate of change of momentum is directly proportional to the force applied.
$$\vec{F} \propto \frac{d \vec{p}}{dt}$$
If the mass of the system remains constant
$$\vec{F} \propto m \frac{d \vec{v}}{dt}$$
Or we can write it as
$$\vec{F} = k m \vec{a}$$
where $k$ is a constant of proportionality.
We define a unit force as a force which can produce a unit acceleration in a body of unit mass. Using $k = 1$, we get the familiar equation
$$\vec{F} = m \vec{a}$$
- 2,235
k the constant of proportionality is ALWAYS taken to be 1 because force is directly proportional to acceleration.
If we use your equation F = kma. This can be seen by graphing force you dependent variable against acceleration you independent variable. The gradient k, passes though the origin with a gradient of 1 due to it's direct proportionality.
(The gradient is k because mass is a constant)
Therefore, 1 (the gradient of your line) = k when this occurs this is called a linear relationship.
Hope this helps.
- 90
