28
Gapped Hamiltonians with a ground-state having long-range entanglement (LRE), are said to have topological order (TO), while if the ground state is short-range entangled (SRE) they are in the trivial phase. The topological properties of a system with topological order (such as anyonic statistics, ground-state degeneracy etc.) are protected for any perturbations of the Hamiltonian that does not close the energy gap above the ground state. See more details here.
If we further require that the system is protected by a symmetry $G$, the LRE states split further into several classes called symmetry-enriched topological order (SET). The SRE state (which is trivial without symmetry protection) is also split into several classes called symmetry protected topological order (SPT). The added physical features of these systems (such as gappless edge-states) are only protected for perturbations which do not close the gap and do not break the symmetry $G$.
Topological insulators are know belong to SPT states, they are SRE and their topological properties are only protected by a symmetry. Related cousins to topological insulators are topological superconductors. In this context, one usually think of superconductors as insulators + particle-hole symmetry (which comes from the Bogoliubov de Gennes Hamiltonian + Nambu spinor notation). This might lead you to conclude that topological superconductors are also SPT states.
However, it is known (by some) that superconductors cannot be described by a local gauge-invariant order-parameter as usual symmetry-breaking phases of matter (but a non-local gauge invariant order parameter exist.) A s-wave superconductor is actually topologically ordered (and thus LRE), and exhibits anyonic statistics, ground-state degeneracy on higher-genus manifolds, low-energy topological quantum field theory (TQFT) description and so on. It is topologically in the same phase as the famous Kitaev Toric code, the $\mathbb Z_2$ topological order. See details here.
Now, my question is the following: is it wrong to consider topological superconductors (such as certain p-wave superconductors) as SPT states? Aren't they actually SET states?
Heidar
  • 5,541
Let me first answer your question "is it wrong to consider topological superconductors (such as certain p-wave superconductors) as SPT states? Aren't they actually SET states?"
(1) Topological superconductors, by definition, are free fermion states that have time-reversal symmetry but no U(1) symmetry (just like topological insulator always have time-reversal and U(1) symmetries by definition). Topological superconductor are not p+ip superconductors in 2+1D. But it can be p-wave superconductors in 1+1D.
(2) 1+1D topological superconductor is a SET state with a Majorana-zero-mode at the chain end. But time reversal symmetry is not important. Even if we break the time reversal symmetry, the Majorana-zero-mode still appear at chain end. In higher dimensions, topological superconductors have no topological order. So they cannot be SET states.
(3) In higher dimensions, topological superconductors are SPT states.
The terminology is very confusing in literature:
(1) Topological insulator has trivial topological order, while topological superconductors have topological order in 1+1D and no topological order in higher dimensions.
(2) 3+1D s-wave superconductors (or text-book s-wave superconductors which do not have dynamical U(1) gauge field) have no topological order, while 3+1D real-life s-wave superconductors with dynamical U(1) gauge field have a Z2 topological order. So 3+1D real-life topological superconductors (with dynamical U(1) gauge field and time reversal symmetry) are SET states.
(3) p+ip BCS superconductor in 2+1D (without dynamical U(1) gauge field) has a non-trivial topological order (ie LRE) as defined by local unitary (LU) transformations. Even nu=1 IQH state has a non-trivial topological order (LRE) as defined by LU transformations. Majorana chain is also LRE (ie topologically ordered). Kitaev does not use LU transformation to define LRE, which leads to different definition of LRE.
wonderich
  • 8,086
Xiao-Gang Wen
  • 13,725
Let me shortly elaborate -- though not answering (at all? certainly :-) since all these notions are pretty new for me -- about what I know from my pedestrian work on superconductors.
I believe everything is much more complicated when you look at the details, as usual. I may also comment (and would love to be contradicted about that of course) that the Wen's quest for a beautiful definition about topological order somehow lets him going far away from realistic matter contrarieties.
$s$-wave superconductor may be seen as long-ranged topological order / entangled state, as in the review you refer to : Hansson, Oganesyan and Sondhi. But it is also symmetry protected. I think that's what you call a symmetry-enriched-topological-order. I'm really angry when people supposed the symmetry classification for granted. $s$-wave superconductors exhibit time-reversal symmetry in addition to the particle-hole one, and thus a chiral symmetry for free, so far so good. Suppose you add one magnetic impurity. Will the gap close ? Of course not ! The gap is robust up to a given amount of impurities (you can even adopt a handy argument saying that the total energy of the impurities should be of the same order than the energy gap in order to close the gap). You may even end up with gapless-superconductor... what's that beast ? Certainly not a topological ordered staff I presume. More details about that in the book by Abrikosv, Gor'kov and Dzyaloshinski. So my first remark would be : please don't trust too much the classification, but I think that was part of the message of your question, too. [Since we are dealing with the nasty details, there are also a lot of predicted re-entrant superconductivity when the gap close, and then reopens at higher magnetic field (say). Some of them have been seen experimentally. Does it mean the re-entrant pocket is topologically non-trivial ? I've no idea, since we are too far from the beautiful Wen's / east-coast definition I believe. But open -> close -> open gap is usually believe to give a topologically non trivial phase for condensed matter physicists.]
So my understanding about this point is: what does the symmetry do ?
  • If it creates the gap in the bulk an/or the gap closure at the edge, then it's not a good criterion. Most of the symmetry like this are generically written as chiral or sub-lattice symmetry (the $C\equiv PT$ in the classification). Some topological insulators only have this symmetry (grapheme in particular if I remember correctly), since the particle-hole ($P$) symmetry defines superconductors. According to Wen, this situation does not lead to topological order in the discussion we have previously.
  • If the symmetry reenforces the gap, then it protects you against perturbation. Once again, the time-reversal symmetry of the $s$-wave superconductor protects against any time-reversal perturbation (the Anderson theorem). But it is not responsible for the appearance of the gap ! I confess that's really a condensed-matter physicist point of view, which could be really annoying for those wanting beautiful mathematical description(s). But clearly the $T$-symmetry should change nothing about the long-ranged-entanglement for $s$-wave (according you believe in of course :-)
As for $p+ip$, it's also called polar phase in superfluid (recall there is no $p$-wave superconductor in nature at the moment, only in neutral superfluid). As Volovik discuss in his book, this phase is not stable (chapter 7 among others). It is sometimes referred as a weak topological phase, which makes no sense. It just corresponds to a fine tuning of the interaction(s) in superfluid. B-phase is robust, and fully gapped. So the pedestrian way is just a way to say that the $p+ip$ is not robust, and that you should have a structural transition (of the order parameter) to the more robust B-phase. NB: I may well confound the names of the subtle phases of superfluid, since it is a real jungle there :-(.
Finally, to try to answer your question: I would disagree. A topological-superconductor (in the condensed matter sense: a $p$-wave say) does not have $T$ symmetry. So it's hard for me to say it is symmetry-enriched the way I used it for $s$-wave. That's nevertheless the symmetry reason why $p$-wave (if it exists in materials) should be really weak with respect to impurities. [Still being in the nasty details: For some reasons I do not appreciate fully, the Majorana may be more robust than the gap itself, even if it's difficult to discuss this point since you need to discuss a dirty semiconductor with strong spin-orbit and paramagnetic effect in proximity with a $s$-wave superconductor, which is amazingly more complicated than a $p$-wave model with impurities, but this latter one should not exist, so...] Maybe I'm totally wrong about that. It sounds that words are not really helpful in topological studies. Better to refer to mathematical description. Say, if the low energy sector is described by Chern-Simons (CS), would we (or not ?) be in a topological order ? Then the next question would be: is this CS induced by symmetry or not ? (I have no answer for this, I'm still looking for mechanism(s) about the CS -- an idea for an other question, too).
Post-scriptum: I deeply apologize for this long answer which certainly helps nobody. I nevertheless have the secret hope that you start understanding my point of view about that staff: symmetry may help and have an issue in topological order, but they are certainly not responsible for the big breakthrough Wen did about long-ranged-entanglement. You need a local gauge theory for this, with global properties.
FraSchelle
  • 11,033
