I was wondering if someone could provide me the name of the following equation
$$\square \varphi - \tilde{m}^2 \varphi = 0,$$
where $\square := \partial_t^2 - \nabla^2$. I am specifically seeking information on the physical interpretation of this equation. This comes from the minimisation of the following action
$$S = \int \frac{1}{2} (\partial_t \varphi)^{2} - \frac{1}{2} (\delta^{ij} \partial_i \varphi \partial_j \varphi) + \frac{1}{2} \tilde{m}^{2} \varphi^{2} \, dx \, dt$$
Clearly, it is similar in form to the Klein-Gordon equation, but with an imaginary mass $m \to i \tilde{m}$. I have read that the quartic potential for the Klein-Gordon equation with this imaginary mass
$$V(\varphi) = -\frac{1}{2} \tilde{m}^2 \varphi^2 + \frac{1}{2} \lambda \varphi^4$$
leads to spontaneous symmetry breaking, as referenced in this PBS spacetime video (starting at 10:29), but am not sure what is supposed to be happening when $\lambda = 0$.
I apologise if this question is not clear enough. I don't know enough about the equation above to know where to look for such information, nor the kinds of questions that I really want to ask about it, and this makes it rather difficult to ask a good question as per the site requirements.
For what it's worth, a scalar field with an imaginary mass is called a tachyonic field. It should be stressed that it is not superluminous, cf. e.g. this Phys.SE post, but since the "wrong-sign" quadratic potential by itself is unstable, it must be accompanied with a higher-order stable potential, typically a $\phi^4$ potential. The Higgs field is an example.
