Measurement units are defined in relation to some amount of physical quantity or physical phenomena. I have a doubt if certain amounts of a certain physical concept can never be measured by a given physical quantity.
For instance, suppose I have a rational amount of time written in the form:
$$ \frac{p}{q},$$
Then measuring that through periodic physical process is simple, I run the cycle $p$ times and I see how much is the $q$th part of it..., but how would I see the amount of seconds for an irrational amount of time? By the very definition it can't be written as "a part of some number of cycles" anymore.
So, is it impossible to ever be able to 'detect' or 'measure' an irrational amount of stuff?
Edit: my question is only loosely related to the dupe because mine is about dectability/measurability rather than existence.
5 Answers5
is it actually possible to measure irrational time through such a definition of a second?
Sure, simply use a different frequency standard. There is no reason that you must use caesium as your only possible frequency standard.
Any measurement will have some uncertainty. Within that region of uncertainty there will be an infinite number of rational numbers and an infinite number of irrational numbers. So choosing to use an irrational or a rational number is entirely a matter of choice. Either will fit the data just as well.
So the process would go like this: choose any different frequency standard whose period, in seconds, is $T\pm \delta T$. So then let $T-\delta T < T_{ rational} < T + \delta T$ be any rational number in that range and let $T-\delta T < T_{ irrational} < T + \delta T$ be any irrational number in that range. Then if you use the new standard to measure some time interval $nT$ you can equally claim that it is a rational number of seconds, $nT_{rational}$, or an irrational number of seconds, $nT_{irrational}$. Both numbers are equal to within the experimental uncertainty so both are equally valid and equally supported by the data.
Dale
  • 117,350
Yes it’s impossible to get a direct measurement whose result is irrational. But it’s not so much that you’re comparing to a reference quantity but rather because every measurement has finite precision and is therefore rational.
On the contrary, if you do an indirect measurement and use a theory calculation based on your direct measurement then your indirect result can be irrational. For example if you measure the radius of a circle and infer it’s circumference using $\pi$ or if you use a clock which is know to tick at an irrational multiple of the cesium clock transition frequency (though I don’t know how you would come by such a clock in practice).
Jagerber48
  • 16,234
You can not measure anything irrational, if you for example measure the circumference of a circle, you will never have a multiple of pi. The concept of measuring is allways comparing with a unit and find the rational parts or multiples of it. you would not even know exactly what pi s or e kg are.Since e and pi are just names for something you can never know in our decimal system.
trula
  • 6,940
Yes
Since both rational numbers $\mathbb{Q}$ and irrational numbers $\mathbb{I}$ are dense in the reals $\mathbb{R}$, you can measure in either rational or irrational quantities. That is, for any measurement, there will be both rational and irrational numbers arbitrarily close to the center of the measurement error region. Rational or irrational measurements only make sense if one has zero measurement error.
Example:
Define a piinch as $\pi$ inches. If we lathe a round dowel down to an inch thick, then we can ink the top and bottom of the dowel. Then we can make a measuring tape with demarcations of piinches by rolling the dowel over a blank tape measure. We can similarly mark fractional piinches on a tape measure.
Now you have the ability to measure length in piinches or fractions of a piinch. Any measurement with a piinch measuring tape (number of piinches and fractional piinches) will be an irrational number of inches.
For any length $l$ for an arbitrarily small error $e$, there will be some fractional values $x$ in inches and $y$ in piinches within $e$ of $l$.
-1
You can certainly take a measurement and end up with an irrational number.
Here's an example of one way to do that. Suppose that you have a lump of a clay-like material and you want to determine its volume. One option is to roll it into a cylinder, and measure the radius and height of that cylinder. Suppose that you measure this cylinder and find that it has a height of $\def\cm{\ \mathrm{cm}} 2.66 \cm$ and a radius of $1.1 \cm$. Then you've measured its volume as $2.66 \cm \cdot \pi \cdot (1.1 \cm)^2 = 3.2186 \pi \cm^3$, which is an irrational number.
Now you can use this cylinder to measure irrational amounts of time. Suppose that you have a tiny faucet that's calibrated to put out $1 \cm^3$ of water per second. Then you take your cylinder and use it to displace some water into a test tube, and then you open your faucet into a second test tube and close the faucet again once the amount of water in the two test tubes is equal. You just measured out $3.2186 \pi$ seconds.
Of course, these methods of measuring aren't exact, and arguably, they're pretty silly. But the measured values that you end up with are definitely irrational numbers.
Sophie Swett
  • 2,137
