I have a difficulty understanding the various explanations of baryon acoustic oscillations that I've been reading. Even on this site, I haven't been able to find answers that directly address the following issues:
My image of these oscillations goes something like the following: I imagine an overdensity in the baryon-photon fluid oscillating in and out kind of like the oscillations of the surface of a drum, these oscillations being due to the gravitational attraction of the overdensity pulling it together, and radiation pressure pulling it apart. Just like the surface of the drum pushes on the surrounding air to create travelling sound waves, I imagine that this overdensity pushes on the surrounding fluid to create travelling sound waves in it, travelling at a little over half the speed of light. With this in mind, here are some issues:
It is explained that the biggest spherical sound waves are those with a radius equal to the sound horizon distance. This is often demonstrated empirically with the BAO bump in the correlation function of the distribution of galaxies. But if these overdensities create continous travelling sound waves, then why dont we get several consecutive bumps, separated by the (current) proper wavelength of the waves? Is it because various overdensities have various frequences of oscillation, thus producing sound waves of different wavelengths such that they deconstructively interfere, except for the first bump, which is common for all oscillations (radius equal to the sound horizon distance)? But if this is true, then why is it said that the various acoustic peaks in the CMB power spectrum corresponds to various states of oscillation (for instance that the second peak corresponds to a compression and then a rarefaction, or a compression, rarefaction and then compression for the third peak etc.)? Shouldn't there be some kind of destructive interference here too (except for the first peak)?
Also, it's been said that the first peak in the CMB spectrum corresponds to overdensities that have just got enough time at recombination to reach maximum compression. But if the radius of the sound waves that this peak corresponds to is the sound horizon distance, then surely these waves must have travelled since the Big Bang, meaning the compression that lead to the emission of these sound waves must have happened right after Big Bang.
