I've been trying to follow this post on deriving the Biot-Savart law from Maxwell's Equations but am getting stuck on this step:
$$-\frac{\mu_0}{4\pi}\iiint{\nabla\times\frac{J}{|r-r'|} d^3r'}.$$
Mainly the curl of current density part which would expand to:
$$\nabla\times\frac{J}{|r-r'|}=\frac{\nabla\times J}{|r-r'|}+\nabla\frac{1}{|r-r'|}\times J$$
The only way this would reduce to $\frac{|r-r'|\times J}{|r-r'|^3}$ would be if $\nabla\times J=0$.
So I tried showing that $\nabla\times J = 0$ in a steady-state situation, however, I'm getting stuck.
Assumption: Steady-state current which implies that for all of space and time $\frac{\partial B}{\partial t}=0$
We start with Ampere's law,
$$\nabla\times B=\mu_0J+\mu_0\epsilon_0\frac{\partial E}{\partial t}$$
Curl of both sides
$$-\nabla^2B=\mu_0\nabla\times J+\mu_0\epsilon_0\frac{\partial(\nabla\times E)}{\partial t}$$
And because $\nabla\times E = -\frac{\partial B}{\partial t}$
$$-\nabla^2B=\mu_0\nabla\times J-\mu_0\epsilon_0\frac{\partial^2 B}{\partial t^2}$$
$$\mu_0\epsilon_0\frac{\partial^2 B}{\partial t^2}=\mu_0\nabla\times J+\nabla^2B$$
However, this is where I'm getting stuck, there are two scenarios for $\partial^2 B / \partial t^2 = 0$: Either $\nabla^2 B$ is zero meaning that $\nabla\times J$ would also be zero, or that $\nabla^2 B$ is non-zero meaning that $\nabla\times J=-\nabla^2 B$.
So now I would need to show that $\nabla^2 B=0$ which I'm not sure is true (For example, wouldn't it be $\infty$ at the wire - assuming thin wire?)
So my question is: is $\nabla\times J=0$ in steady-state? If so, where am I going wrong in my proof?
