When we derive the formula for potential energy caused by the torque of a dipole in uniform electrical field we get $U = -pE \cos \theta$. And my textbook tells me that the when the dipole is kept parallel to the electric field, the angle made is zero $\cos\theta = 1$, thus the potential energy $U$ is $-pE$. The textbook also tells me that this is the minimum energy attained by a dipole in external electric field ($U = -pE$) and the configuration is stable. But since energy is a scalar quantity, it isn't supposed to have direction, So, what does the negative symbol signify?
Cross
  • 3,360
Absolute values of the potential energies of systems do not have any physical meaning. It is the change in potential energy that has a physical meaning.
When the potential energy of a dipole system is derived, the following approach is used: $$U_f - U_i = \int dW = \int_{\theta_i}^{\theta_f} \tau\cdot d\theta$$ $$U_f - U_i = pE \int_{\theta_i}^{\theta_f}\sin\theta\cdot d\theta,$$ and consequently, $$\boxed{\Delta U= -pE(\cos\theta_f - \cos\theta_i).}$$
From here, a reference configuration is chosen for the dipole system such that $U_i = 0 \ \text{at} \ \theta_i = 90^{\circ}$, purely for convenience, which gives the formula $U = -pE\cdot\cos\theta$.
Naturally, any positive or negative signs arise only due to this choice of convention and do not possess any meaning as such.
Hope this helps.
Buzz
  • 17,816
Cross
  • 3,360
