Background (isotropic screening): Consider a quasi neutral plasma. An ion/electron in a dense plasma attracts opposite-charged particles and repels those with the same charge, thereby creating a "cloud" around itself. This microscopic cloud shields the particle's own charge, causing its Coulomb field to fall off exponentially: the particles in the medium interact via a screened version of the, more fundamental, Coulomb interaction, see e.g. Wikipedia.
The standard derivation of this "screened interaction" is in terms of the screened Poisson equation, which can arise from different approaches to the problem, like the Thomas-Fermi approximation, Lindhard theory, or the treatment of Debye, see e.g. this paper and these notes.
In any case, the screening length $\lambda$ defines a screened potential (Yukawa potential) between the particles in the plasma:
$$ V(r) \propto r^{-1} \, e^{-r/ \lambda} $$
In this case, the screening length $\lambda $ is just a single number (the "cloud" is spherical)... but what if there is a strong enough magnetic field? Now we have a preferred direction, the one of the magnetic field, and also the "cloud" could be affected.
Question: The derivations of $\lambda$ I am aware of seem not to consider the possible presence of a macroscopic magnetic field. I suspect that, in the presence of a magnetic field that breaks the isotropy, we should have 2 different screening lengths in the plane orthogonal to the magnetic field and in the direction of the magnetic field: the polarization cloud is not spherical and the screened Coulomb interaction is not invariant under rotations, e.g.
$$ V \propto r^{-1} \, e^{-{r}_{1} /\lambda_1 - r_2/ \lambda_2} $$
where $r_{1,2}$ is the length of the projection of $r$ parallel or orthogonal to the magnetic field direction and $\lambda_{1,2}$ can depend on the magnetic field strength (when there is no macroscopic magnetic field, then $\lambda_{1}=\lambda_{2}$).
Is there something like an "anisotropic" version of the screened Yukawa potential? This should define the effective interaction potential between particles in, say, an overall neutral plasma of electrons and positive ions (or protons) in a strong external magnetic field. References are welcome.
Edit: After the comments and the first answer, it still seems to me that we should find two different screening lengths (parallel and orthogonal to the magnetic field direction). In fact, the electrons will tend to "move in circles" orthogonally to the magnetic field, which may influence the screening.
Quillo
  • 5,541
  • 19
  • 46
I'm not an expert, but I think that there is no net effect, in part due to the Bohr-Van Leeuwen theorem.
First of all, a static magnetic field does not influence the thermal charge fluctuations which cause the screening, so the potential should not change.
You could think however, that the addition of an extra charge could somehow generate a magnetic field, which is where the mentioned theorem comes to the rescue. Since classically you can't have any magnetisation, you should not get a magnetic version of Yukawa potential.
Hope this helps.
LPZ
  • 17,715
  • 36
