It was noticed in the 1960s that chiral perturbation theory, describing the goldstone-bosons (pions) of the breaking $SU(N_f)_L \times SU(N_f)_R \to SU(N_f)_V$ of the chiral symmetry, has solitonic solutions (skyrmions), so long as you include four-derivative terms in your chiral lagrangian (the original proposal just used one of these terms). As I understand, there are various reasons to believe this skyrmion can be identified with nucleons such as the proton/neutron, delta baryons, etc:
  • Their mass has the correct linear in $N_c$ scaling as expected from large $N$ calculations.
  • The conserved topological current describing the winding number of the solitonic solution can be identified as the $U(1)$-baryon current - if you gauge your chiral perturbation theory with weak interactions, you can see that you recover the $U(1)_\text{Baryon} SU(2)^2$ anomaly
  • With a bit of work, you see exactly the right excitations, in terms of isospin and spin representations
When I look in the literature, I mainly see papers from the 1980s hyping all of this up, and it seems very solid. What I am confused about is (to quote Witten) to what extent the skyrmions actually are baryons. To be concrete:
Are there any predictions from Skyrmionic theory of baryons that are not compatible with our current measurements/understanding of baryon phenomenology?
The original papers include calculations of various physical quantities which match up to ~30%, which seems fine to me given that the original Skyrme model only contains one of the four-derivative terms of the chiral-lagrangian, while it seems to me the "proper" thing to do would be to include all terms of the same order in chi-PT with coefficients extracted from experiment/lattice, and then perform skyrmionic calculations. It's believable to me that going to higher order will fix these numerical issues
QCD_IS_GOOD
  • 7,145
I think there are two basic reasons why there has not been much work on skyrmions in QCD over the past $\sim$ 25 years.
  1. The model is not systematically improvable: In the Skyrmion model, stability of the soliton comes from a balance between two-derivative and four derivative terms in the chiral Lagrangian. This means that the four-derivative contribution is not parametrically small, and higher derivative (six, eight, $\ldots$) are not small either. This is contrast to applications of the chiral lagrangian in the meson sector, where higher derivative terms are suppressed, and systematic calculations are possible.
  2. Lattice QCD provides accurate (few per cent level) predictions of properties of the protons. These are based on correlation functions of local three-quark operators. It is not clear how one would use these results to determine in what sense the skyrmion is an approximate description of the proton in the real world. Indeed, I would have expected that if the proton is a soliton of an emergent collective field, then the coupling to local $qqq$ operators is small (this is not the case).
There has been some recent work on skyrmions in connection with the AdS/CFT correspondence, and AdS/QCD models, see here.
Thomas
  • 19,250
I don't know if this is exactly what you're looking for, but I have found and greatly enjoy this paper: https://www.ncbi.nlm.nih.gov/pmc/articles/PMC10387112/
