Assume we have an object of 1 kg, at rest and we invest 100 Joules of energy to accelerate it. The resultant velocity can be calculated by
$$ v = \sqrt{\frac{2K_{e}}{m}} $$
so, $$ \sqrt{\frac{2 (100)}{1}} \simeq 14.14 m/s $$
But because of relativity if we invest more and more energy, we won't get the same rise in the velocity as the relativistic mass goes on increasing and resultant velocity rises more and more slowly and it will approach at best the speed of light on spending infinite amount of energy. What is the formula or method to calculate the final relativistic velocity of an object of mass $m$ if I invest $K_{e}$ amount of energy to it?
Your first formula is incorrect because it's using the newtonian version of the kinetic energy. In special relativity it becomes:
$$K_e=(\gamma-1)mc^2=\left(\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}-1\right)mc^2$$
After a bit of elbow grease, you get:
$$v=c\sqrt{1-\frac{1}{\left(1+\frac{K_e}{mc^2}\right)^2}}$$
Notice the approximation $K_e/mc^2\ll 1$ restores the formula of Newtonian mechanics.
Miyase
  • 6,342
