My question is tied closely to this one, asked a while back on the website. As far as my understanding goes, a rainbow is formed by sunlight undergoing two refractions and a reflection inside individual water drops, and then falling on our eyes. An upper drop disperses red light the most, angling it towards our eyes and a lower drop similarly angles the less dispersed violet light towards us, after reflection. However, the way it looks to me is that there's no room for any of the other colours to fill the gap between the red and violet light. That pattern seems to read
vibgyo R V ibgyor
from top to bottom, the bold letter indicating the colours seen upon reflection by us. So where do the other colours come into play here? Also, does this pattern indicate that upon moving up in the vertical direction, we would begin to see the rainbow invert its colours?
Picture from above linked question
The diagram produced in the question has a couple of errors and almost answers the question.
To a very good approximation the rays coming from the Sun are approximately parallel and the reflection from the raindrop is not the result of total internal reflection.
The important things to note is that a rainbow as a result of the reflection and refraction due to many raindrops and only the light rays entering the eye produce an image of a rainbow on the retina.
Note the cones of rays which do not enter the eye.
This last image is to emphasise the points about many raindrops producing a rainbow and only the light entering the eye is detected by the eye.
Farcher
  • 104,498
When light hits the edge of the droplet (from the inside as well as from the outside), it can undergo a reflection as well as a refraction. So there can be several reflections inside the droplet before the light comes out. Because of that, light is dispersed many directions.
This also explains you can observer a secondary rainbow, which is also a circle (only partly visible, usually) and concentric to the primary one.
Miyase
  • 6,342
The graphics just shows two raindrops, although of course there are lots of raindrops in between those two.
It shows that every raindrop emits a bunch of rays, dispersed depending on the wavelength (color), with violet coming back closest to the incoming ray, and red farthest.
The upper raindrop shown is one where the red end of the spectrum just happens to reflect into the observer's eye, and from the lower one, the violet end just hits the eye. (See below for the sloppy creation of the graphics...)
From the many raindrops in between, some intermediate point of their spectrum (between red and violet) hits the observer's eye, thus producing the well-known continuous rainbow spectrum.
Sadly, the graphics has been created rather sloppily:
  • The red ray from the upper raindrop doesn't hit the guy's eye, but his hair, so this raindrop wouldn't be visible in the rainbow.
  • The violet ray from the lower raindrop doesn't hit the guy's eye, but his mouth, so this raindrop as well wouldn't be visible in the rainbow.
  • The incoming rays from the sun should be parallel - the sun is so very far away that the angle difference between the connections to the two raindrops is below a millionth of a degree.
  • And it would have helped to include a third raindrop in between.
