I'm looking at the answer Michael gave to my question. Does this imply that under parameterized post-Newtonian formalism, under the $β1$ factor for kinetic energy, the gravity of a mass doubles as it approaches $c$? Or is it some other factor?
The kinetic energy of a relativistic object is given by $K = (\gamma - 1) m c^2$, where $\gamma = 1/\sqrt{ 1-v^2/c^2}$. Since $\gamma \to \infty$ as $v \to c$, the kinetic energy of an object diverges as $v \to c$, as does the ratio of its kinetic energy to its rest mass (which is what the PPN parameter $\beta_1$ is talking about.
That said, the PPN formalism is only really well-suited for sources moving at speeds much less than the speed of light (as has been pointed out in the comments). If you were to try to apply it to an object moving at relativistic speeds, there would be terms in the full metric that the PPN formalism ignores. Note that this also means that you probably can't use the PPN formalism to analyse a kugelblitz spacetime, as mentioned in your previous question.
- 54,357
