How occurs the enantiomorph of the mirror?
I would like to know how occurs the RELATIONS OF THE RAYS with the mirror and the image, everything that happens to be flipped image from the right to the left.
user73276
  • 101
From the link in the comments it should be clear that a mirror does not flip left/right but rather in/out. The mirrored image is flipped at the (surprise!) mirror plane. If you look at the mirror at an angle $\alpha$, you are looking at something that has the same angle between the perpendicular and the point where the "looking-ray" hits the mirror. This is independent of the direction in which you are looking. The physical explanation of the rays can be reduced to: Incoming angle equals outgoing angle.
