If lasers are collimated, what causes them to decollimate? Their production system seems to suggest a completely linear, collimated light source, but they do spread out over large distances. The same holds for synchrotrons. Why does this happen?
There is a fundamental limit to the collimation of a laser due to diffraction. Assuming the laser beam profile is a uniform disk it will be diffracted to an Airy disk at large distances, and the angular spread is approximately given by:
$$ \theta \approx 1.22 \frac{\lambda}{d} $$
where $d$ is the beam diameter. Assuming a diameter of 1 mm, which seems a reasonable estimate for most lasers I've seen, you get an angular divergence of about 0.6 milliradians for 500nm light.
I know next to nothing about the design of lasers, but Wikipedia reports the divergence as commonly less than 1 milliradian, which fits with the above estimate.
John Rennie
  • 367,598
Following John Rennie's answer I read the 1st paragraph of Collimated light at Wikipedia . Last 3 lines stated that "Collimated light is sometimes said to be focused at infinity.Thus as the distance from a point source increases, the spherical wavefronts become flatter and closer to plane waves, which are perfectly collimated."
Does it mean that for a light source with enough power we will have a perfectly collimated light after a certain distance far away from source when it has already passed its divergent phase because of spherical wavefronts ? So after a certain distance we have a perfectly parallel plane wavefronts and beam won't be divergent any more!
Lasers are not perfectly collimated.
In fact, according to an analogue of the Heisenberg Uncertainty Principle, it's fundamentally impossible to create a perfectly-collimated beam of light from a finite-sized source.
Why? If the light is traveling in the z direction, and it's perfectly collimated, then the photon momentum in the x and y direction is exactly zero. Which means the photon position in the x and y direction is completely unknown. Again, only a wave with an infinitely-wide cross-section can be exactly collimated.
A laser beam is never very large, and certainly not infinitely large. The size of the laser beam depends on the laser active area (the area producing laser light), and also depends on the lenses you put after the laser. For example, a laser pointer might have its light in a 1mm circular spot (before it spreads out). As a rule of thumb, you can divide the wavelength of the laser light by 1mm. You get a very small number, but it's not zero. That number is more-or-less the smallest possible divergence angle (in radians) that this beam can have.
Although it depends on the application, people who make lasers usually try to have them output something close to a gaussian beam, which is more-or-less the most collimated possible given the finite size of the beam. If you read about gaussian beams, you'll see the tradeoff very directly between the cross-sectional area of the beam and its divergence angle.
Well, it's impossible even to put 100% of the energy into a perfect gaussian beam (once again because the laser has a finite size), but you can get close to 100%. See M2 and beam parameter product for how these things are characterized.
Steve Byrnes
  • 17,082
