24
Some threads here touching speed of gravity made me think about that. This lead to some questions.
  • The speed of gravity was not measured until today (at least there are no undebated papers to that effect).
  • It seems common knowledge/belief among physicists that the speed of gravity is the same as the speed of light.
And this is my question: Is that speed of light = speed of gravity a result of GR or is that fed into the theory? Or is there some evidence from other sources than GR for this? Does the same speed imply some deep-lying relation between gravity and electromagnetism?
Georg
  • 6,965
5 Answers5
10
The special theory of relativity is really enough to see that gravitational signals have to propagate by the speed $c$ which we call "speed of light" because the light is the most commonly understood entity that is moving by this maximum speed. Special relativity is OK to describe infinitesimal deformations of spacetime.
All other massless particles also have to propagate by the same speed $c$ because this speed $c$ is needed to enhance the vanishing rest mass to a finite total relativistic energy. And gravitons are inevitably massless because they don't pick any preferred reference frame - or, alternatively, because gravity is a long-range force. Massive particles could only induce short-range forces (similar to the weak nuclear force caused by W,Z bosons).
Any particle - e.g. neutrino - whose energy is much greater than the rest mass is moving nearly by the speed of light, too. The same thing would hold for massless scalar particles such as the "moduli" (their quanta) if they existed. It's an elementary consequence of the formulae of special relativity. The speed of light is the maximum speed that the information and material objects may pick, by causality, and it's also the typical speed that massless (exactly) and light (approximately) particles actually choose.
So the answer to your last question is No, the appearance of the same speed $c$ doesn't imply any additional dynamical relationship between electromagnetism and gravity - it's a direct and elementary consequence of the special theory of relativity - and its kinematics - that was fully understood in 1905. The importance of the speed $c$ in the scheme of things - because of special relativity - is so high that adult physicists use units in which $c=1$ and they are never ever surprised when $c$ plays an important role - it's exactly the same degree of "surprise" as if the number $1$ appears somewhere in maths.
Luboš Motl
  • 182,599
I think the main argument would be causality. If gravitational disturbances traveled faster than light, presumably you could use them to convey information backwards in time. Although now that I think about it, that argument is based on special relativity. I can't think of a reason it wouldn't carry over to GR, but I don't know whether anyone has explicitly checked.
You can derive from GR the fact that gravitational waves (disturbances in the weak-field approximation) propagate at speed $c$.
I'm not aware that any experimental measurements have been done, since gravity is a weak force and is difficult to measure. Building a "gravity telescope" is a lot more complicated than a regular telescope, although there are plans in place, e.g. LISA, which might be able to detect gravitational waves for the first time, if it gets funded and built.
David Z
  • 77,804
Yes, there is another derivation: String Theory. The action and its QFT implies the existence of not only tachyons (which would move faster than $c$), but two massless particles of spin $1$ and $2$ ... the spin-1 particle is the photon, and the spin-2 particle is the graviton (both must necessarily travel at speed $c$ because of their mass).
Chris Gerig
  • 2,798
The speed of gravity (gravitational waves) is a result of General Relativity theory. The linearized Einstein Field equations result in wave equations describing spacetime ripples propagating with velocity $c$, the same velocity as the speed of electromagnetic waves in Maxwell theory.
JanG
  • 2,237
-3
"speed of light = speed of gravity" is fed into the theory of GR.
