10
I work in quantum information theory/condensed matter and have some very basic questions about AdS/CFT correspondence. For simplicity, I would like to restrict to 1+1 CFT <-> 2+1 AdS. I apologize in advance if the following questions are too basic or ill-posed, clearly owing to a lack of familiarity with the subject. Broadly, I am interested in the relation between boundary translations and bulk diffeomorphims, and what happens in the scenario where the boundary translational invariance is broken by introducing a conformal defect or boundary.
QUESTIONS:
  1. Are translations at the boundary identified with diffeomorphisms in the bulk? More specifically, given a translation at the boundary, what is the corresponding diffeomorphism?
  2. When the boundary translational invariance is broken, say by introducing (A) a conformal defect in the CFT or (B) a boundary, what is the "residual" bulk diffeomorphism invariance (in cases where there is still a dual gravity theory)?
Any pointers or references would be most helpful.
The translations in the CFT are a part of the conformal group, so they're obviously identified with an isometry (diffeomorphism that preserves the metric everywhere) of the bulk!
For the $AdS_{d+1}/CFT_d$ correspondence, the conformal group is $SO(d,2)$ and may be obtained by extending the Lorentz group $SO(d-1,1)$ by the $d$ translations, $1$ scaling generator, and $d$ generators of special conformal transformations. The AdS spacetime has this isometry because it is a $(d+1)$-dimensional hyperboloid of a sort so its isometry is a noncompact version of the $SO(d+2)$ isometry of the sphere $S^{d+1}$.
To see that $SO(d,2)$ contains $d$ mutually commuting translation generators, find a null direction in the $(d+2)$-dimensional space, $x^+=(x^0+x^{d+1})/\sqrt{2}$. Then the generators $J^{i+}$ for $i=1,2,3,\dots d$ commute with each other because $g^{++}=0$.
When an excitation or defect is inserted to the boundary CFT, the state is no longer invariant under some/all translations. The AdS statement equivalent to it is, of course, that the state of the bulk is no longer invariant under the corresponding isometry.
It isn't really an objectively well-defined question to ask "what is the unbroken residual bulk diff invariance". The diff invariance is a gauge symmetry which is an auxiliary tool. We start with a redundant description (redundant space of configurations classically; a redundant, larger than physical Hilbert space quantum mechanically) and we impose identifications given by the gauge symmetry to reduce it to the physical space (configuration/phase space classically, physical Hilbert space quantum mechanically).
There is no "the" right set of gauge symmetries we have to use for a given physical system. That's made clear by the AdS/CFT correspondence, too. The two sides employ very different gauge symmetry principles to reach the final product. The CFT uses e.g. the $SU(N)$ local/gauge Yang-Mills symmetry; there's no trace of it in the bulk description. On the contrary, the bulk theory employes higher-dimensional diffeomorphisms etc. to eliminate the unphysical graviton polarizations, aside from similar gauge symmetries for other bulk fields; there is no trace of diffeomorphisms in the Yang-Mills description.
But whenever you use the covariant gravitational description, the group of diffeomorphisms is completely given by all the coordinate redefinition and this group is completely determined by some general data such as the spacetime topology. We demand the physical states to be invariant under (i.e. annihilated by the generators of) the diffeomorphisms that converge to the trivial map at infinity (near the boundary). The isometries of the AdS space i.e. the conformal transformations are not converging to the identity in the asymptotic region which is why they don't have to keep the physical states invariant.
Luboš Motl
  • 182,599
The area of research you are describing is sometimes called AdS/BCFT and was not really studied much at all until the last couple of years when there were some proposals for bulk duals to interface and boundary conformal field theories, ICFTs and BCFTs. As far as I am aware, there is no consensus on what the bulk dual to a conformal field theory with interface or boundary should even look like, so it's difficult to answer what the residual translation invariance looks like in the bulk. However, there are two proposals of which I am aware, both of which are fairly recent. The first is a
proposal for AdS/BCFT made by Takayanagi et. al.
and the second involves bulk solutions in which full translation invariance is manifestly broken by using an $\mathrm{AdS}$ slicing of $\mathrm{AdS}_3$ inspired by the so-called Janus solution and holographic RG flows;
proposal of Gutperle and Samani (that's me!)
I'll let you peruse these for more details, but let me note that I don't think that anyone who works in this rather niche field views any of this as particularly conclusive.
Urb
  • 2,724
joshphysics
  • 58,991
